What filters does a Rudd UGMC 080 A use - Heating & Cooling
Why does my water heater over flow when we use too much water?
Over flow? You mean you have a major water leak? I'd call a plumber.
Apr 10, 2015 | Water Heaters
My son has a Rudd air conditioner Model UBHC-17J11. Where is the filter located?
If you pull the bottom door off, or where the blower motor is, the filter should be with
sight.
Aug 28, 2011 | Ruud UBHC Air Conditioner
Need step by step instructions to set-up memory lens function for PT AE3000 projector so as to be able to switch between 16.9 and 2.35:1 formats
LENS MEMORY means that
You can save and name the adjusted ZOOM/FOCUS,
H-AREA POSITION and V-AREA POSITION there is just 4 adjustment settings in
memory excluding ASPECT RATIO the aspect ratio depend on signal but you can change manually when needed.
possible ASPECT RATIO and SIGNALS
If VIDEO or S-VIDEO then
ASPECT RATIO
4:3 \ 16:9 \ 14:9 \ ZOOM1 \
ZOOM2 \ JUST
AUTO
\ 4:3 \ 16:9 \ JUST \ ZOOM
you can switch in between
If COMPUTER then
4:3 \ 16:9
4:3 \ 16:9
VGA or SVGA signals
Not switchable with
WIDE480/600/720/768/768-2/800/900 signals
If HDMI then
4:3 \ 16:9
16:9 \ H - FIT \ V - FIT \ ZOOM
1 125 (1 080)/50i, 1 125 (1 080)/60i,
1 125 (1 080)/50p, 1 125 (1 080)/60p,
1 125 (1 080)/24p, 750 (720)/50p and
750 (720)/60p signals
525p (480p) and 625p (576p) signals
If COMPONENT(YPBPR) then
4:3 \ 16:9 \ 14:9 \ JUST \ ZOOM1
\ ZOOM2
625i (576i), 625p (576p)
AUTO \ 4:3 \ 16:9 \ JUST \ ZOOM
525i (480i), 525p (480p)
1 125 (1 080)/24p, 750 (720)/50p,
these are all type of signals and there possible aspect ratios
Feb 06, 2011 | Panasonic PT-AE3000U LCD Projector
RUDD MODEL# UAMB-048JAZ AIR CONDITIONER
service once a year clean dirt and hose the coil out make sure power to outdoor unit is off also make sure you keep a new air filter change about every 2 months you should also have a tech test you pressures this could cause poor cooling also need to clean inside coil also a service tech will probaly need to do this good luck
Aug 30, 2009 | Ruud UAMB Air Conditioner
Aderss of acer service center in banglore
2A, Aisa Glenridge 32, Langford Road
Museum Road, Bangalore, Karnataka 560025
080 41526018
#2A, Aisa Glenridge 32, Langford Road
080 41526018080 41526019080 41526020080 22296068 - Fax
Mar 20, 2009 | Acer Extensa 5420-5687 Notebook
Simpson enviro 080
there is probably something stuck in the filter. take the plastic cap off and clean it out. i had this problem and found a coin wedged in the filter part. once the coin was removed.......good as new!
Jan 05, 2009 | Washing Machines
Rudd central unit frezzing up
One of two problems dirty filter. And if you don't have a filter dirty A-Coil. one solution second one Low on Freon which brings up another problem leak in system somewhere.
Nov 22, 2008 | Ruud Heating & Cooling
Where is the air filter on my rudd airconditioner? i have uhla r-410a
HEY< is this an up flow or down flow air handling unit,,,,(vents in the ceiling or in the floor?) If this is a down flow, then the filter rack is always before or above the the fan. to catch dust before it goes to the fan blades..!
Sep 12, 2008 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
