Question about Samsung Galaxy Tab Tablet PC
The display on my tab 4 looks like there is a posterize camera filter applied to it already tried factory reset and uninstalling all updates
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
Nov 22, 2017 | Tablets & eReaders
I bought a used Samsung Galaxy Tab 4 (8.0) running on AAA Automobile Club towing system on it, I want its original android system back into it, where can I find that specific download? A link please!
Try a Hard Reset which clears everything off it and installs Android new. There are no Android download links.
  • Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8 ... www.verizonwireless.com > Samsung Galaxy Tab 4 (8.0) Before performing a hard reset, ... Home > Support > Samsung > Samsung Galaxy Tab 4 (8.0) > Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8.0) Ask Verizon:
  • How to Factory Reset the Galaxy Tab 4 - YouTube www.youtube.com/watch?v=nZBZYa4nZ18
    • BY ASKTHEANDROIDGUY
    • 3 MIN
    • 110K VIEWS
    2014-05-19 · Video embedded · How to Factory Reset the Galaxy Tab 4 Check Out Our New Website: http://www.RickytheAndroidGuy.com Like us on Facebook: ...
  • SAMSUNG T330 Galaxy Tab 4 8.0" - How to Hard Reset my ... www.hardreset.info/devices/samsung/samsung-t330-galaxy-tab-4-80 Hard Reset SAMSUNG T330 Galaxy Tab 4 8.0" First method: In order to switch off the tablet hold down the Power key for a short while. After that, press and hold ...
  • Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset ... solverbase.com/w/Samsung_Galaxy_Tab_4_8.0:_Hard_Reset_Factory_Reset Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset. From ... How to make a Hard Reset (Factory Reset & Data Wipe) on Samsung Galaxy Tab 4 8.0"? Samsung ...
  • Samsung Galaxy Tab 4: Steps For Hard Reset - Technipages www.technipages.com/galaxy-tab-4-hard-reset How to perform a factory hard reset on the Samsung Galaxy Tab 4 tablet. Technipages Smart phone, gadget and computer tips. ... Samsung Galaxy Tab 4: Steps For Hard Reset.
  • https://www.android.com/tablets
    May 23, 2016 | Samsung Tablets & eReaders
    Galaxy tab 4 encrypted how to do factory reset
    Gobto your settings then go to general then go to backup and reset open backup and reset and there you can factorybdata reset your device.
    Feb 19, 2016 | Samsung 10.1 Galaxy Tab 4 16GB White
    I purchased my tablet from a pawn shop yesterday and don't know how to hard reset it due to there being a lock pattern on it and don't know the g mail account associated with it
    1) Power down your tablet.
    2) Tap the power-on button and volume down button at the same time
    3) Tap and hold the power-on and volume down buttons until you see the android alien icon
    4) tap the power-on and volume up again at the same time until you see the System recovery menu.
    Android System recovery menu
    Volume up/down to move highlight;
    power button to select.
    Options are below
    reboot system now
    apply update from /sdcard
    wipe data/factory reset
    wipe cache partition
    recovery system from backup
    update rk image from /sdcard
    select (wipe data/factory reset) bush pushing the power button to select it and restart the device after.
    Oct 17, 2015 | Dragon Touch Touch R10 10.1 Google Android...
    How to fix my Facebook app on Android tablet. No longer looks or preforms like the normal app. Think malware is involved.
    A few suggestions:
    1. Ensure you are using a good (fast) wifi connection.
    2. Make sure there are not too many apps running in the background on the tab at the same time (using resoures). Close unused/unneeded ones.
    3. Check for updates to your tab's system software. If available install the latest update.
    4. Log into Facebook with a browser app instead (i.e. chrome, firefox, etc.). Check if there is a problem after 30 min. or so accessing Facebook this way.
    5. A full system reset will probably fix the problem (unless there is also a hardware component problem with the tab). But it is a lot of work to reinstall apps, accounts, etc. (... consider only as a last resort).
    Aug 25, 2015 | Tablets & eReaders
    How can I fix my galaxy tab, it's displaying like cartoon visuals and I can't see the images clearly..
    Have you tryed to reset it, plug in to pc run an update, check settings display, or factory reset
    Jul 05, 2015 | Tablets & eReaders
    How do I restore my Samsung tablet to the origional form?
    Hi Erica, the only way to restore your tablet to original form will be to factory restore/reset.
    This is how to do it.
    1: Click on your Settings Icon.
    2: Click on Back up and reset
    and Automatic Restore so they are clicked, then click on Factory data reset.
    3: Click on Reset Device
    4: Then click on Delete all
    Your tablet should now restart and look like the day you bought it.
    Please note that the factory reset might take a few minutes to do the reboot. Don't turn of or disturb the the rebooting, wait until it finish by itself.
    25387709-53uihbay4bejfnwqkcsmqi02-5-10.jpg 25387709-53uihbay4bejfnwqkcsmqi02-5-3.jpg
    25387709-53uihbay4bejfnwqkcsmqi02-5-15.jpg 25387709-53uihbay4bejfnwqkcsmqi02-5-6.jpg
    Hope this helps.
    Jan 28, 2015 | Samsung Galaxy Tab on 3 Mobile Tablet PC
    Android System Recovery
    Obvious question is what the tablet had been doing during its' last use.
    Was something newly installed, was system or apps updated, etc. ?
    Were all the APPs and or system shut down properly ?
    Did update or installation recommend restarting system, prior to use ? Were multiple installations / updates performed ?
    Your device appears to be in a recovery boot-loop.
    As stupid as this may sound ...
    Is the power adapter connected ? Let battery charge for at least 30 minutes and try again.
    If battery is low, it may not complete the reset. - you should have seen something on the screen, denoting " wipe and reset " procedure and completion - prior to (#1) Rebooting device
    Per your post, you have already (#4) wiped the data and instructed the device to reset to factory settings, then (#1) Reboot system.
    That is the generally accepted reset method
    This problem is not all that uncommon, it generally results when attempting reset, internal boot commands error for what ever reason. ( can not find the factory restore / recovery file set ).
    This problem is more common when "fixes ", Specialty " Roots " or "mods" have been installed by the user - making changes to the boot program and commands OR when manufacturer files have been deleted / moved from system access. - Common suggestion is to work backwards through the mod processes and / or attempt to re-install mod or follow the special mod recovery method.
    Without having available the proper ROM " flash " update / installation file(s), and you may " brick " the device.
    I recommend you go to manufacturer site and check for available ROM files, reset / reinstallation processes ( memory card method ? )
    You state the tablet is less than six months old. You may want to contact manufacturer for possible warranty service.
    They will most likely ask the referenced obvious questions, to better understand the cause / nature of the device failure and recommend the best immediate possible solution.
    This may not be what you seek, I hope it will provide better direction.
    Apr 20, 2014 | Hannspree SN10T1 101 Tablet
    My V55 android tablet is locked and i dont know the email
    You can try to do factory reset on your tablet so that your tablet would get unlock. 1.Press the power-key and volume-down key at the same time until the phone get into the recovery mode.
    2.Press home key to get into next interface.
    3.There will be four choices: reboot system now;apply update from external storage ;wipe data/factory reset;wipe cache partition.
    4.Use "Vol+" and "Vol-" to move the cursor up and down.
    5.press power key to select wipe data/factory reset.
    Jan 22, 2013 | ZTE Optik / V55 CDMA Tablet
    Samsung Galaxy Tab Tablet PC Logo
    Top Samsung Tablets & eReaders Experts
    Jaime Hernandez
    Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
