Question about Clymer Marine Maintenance and Repair Manual '99 '02 Yamaha 115 250 HP 2 stroke Outboards
2002 90hp yamaha 2stroke i replaced the ten pin electric harness.i installed new remote control.but i have analog gauges. how do i connect to them . the six pin does not match up
    Sergeant:
  • 331 Answers
Hello, you'll need a second wire harness for the instruments. And also a hose for the speedometer.
Posted on Oct 04, 2017
How do i change oil in a 1991 yamaha g2 golf cart
It's a basic yamaha 2stroke eng. there's a drain plug on bottom. Replace with yamaha 2stroke gear oil 1.8 quarts check filter which is located new fuel door. Replace or clean with solvent( replace) never mix oil only one brand should be use at a time. Yahmalube or simial
Oct 04, 2014 | Motorcycles
In and out of limp mode
My 2 experiences with limp mode was on a 93' Chevy. 1 time was the ecm, but it didn't reset until I replaced the ecm. The other time was the main electrical plug that comes from the ecm. The largest electrical plug on the trans. I unplugged it and there was trans fluid inside the plug on the 16 pins that connect the external wire Barnes to the internal wire harness of the trans. This required a new harness inside of the trans and replacing the external harness near the trans. Not an easy fix and may not be your issue, but this issue would "come and go". Fluid would short out the communication at the pins.
Aug 22, 2017 | 2002 Dodge Neon
What's your problem?code F35 is coming up
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned. This problem could be caused by a failed analog pressure sensor, a problem with the air tube connection between the analog pressure sensor and the bottom of the washer tub or a failed central control unit.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
A loose wiring connection or a broken wire harness could be causing this problem. You can remove the top panel of the washer by taking out the screws at the very back of the top panel. Pull the panel back slightly and then lift it up and off of the washer. Check the wire harness connected to the analog pressure sensor. Also check the air tube connected to this component. If these connections are okay, check the analog pressure sensor connection on the central control unit. THE IMAGE BELOW (click the link for zoom) shows the location of the central control unit on a similar model of washer and also provides a wiring diagram. The analog pressure sensor harness plugs into the central control unit on the PR8 connector. Make sure that this connection is secure. Look for damage to the wire harness.
If this dont solve it, I suggest replace the analog pressure sensor (shown in THIS LINK). Additionally, keep in mind that if your device is less than a year old, then this component is under warranty and should be replaced by a dealer technician.
Oct 13, 2011 | Kenmore Elite 45986 Front Load Washer
How do I fix the light in the heater control?
The heater control will have to be removed and possibly disassembled to get at the bulb.
1995-98 Models
  1. Disconnect the negative battery cable.
  2. Remove the radio/HVAC controller cover by depressing the center pins inward to release the push pin fasteners. Be careful not to push the center pins all the way through the fasteners.
  3. Remove the push pin fasteners and pull the radio/HVAC controller cover rearward.
  4. If equipped, disengage the traction control/fog lamps/rear defogger electrical connector.
  5. Remove the radio. Refer to the Radio removal and installation procedure, later in this section.
  6. Disengage the electrical connectors behind the controller face. Remove the wiring harness clip from the module boss.
  7. Disengage the temperature and mode cables from the controller assembly by squeezing the lock tabs together while pulling the cable housing straight up. Pull the cables straight up to disengage them from the control lever pins.
  8. Remove the HVAC control panel screws, then carefully pull the panel forward and remove it from the vehicle. To install:
  9. Position the HVAC control panel to the dashboard and install the retaining screws. Tighten the retaining screws to 22 inch lbs. (2.5 Nm).
  10. Install the white temperature and black mode cables over the pins.
  11. Install the cable housings into the clip grooves, then push down to lock them into position.
  12. Reattach the electrical connectors to the back of the control panel face. Install the wiring harness clip to the module boss. Be sure that the wiring harness does not bind with control lever movement.
  13. Install the radio.
  14. If equipped, reattach the traction control/fog lamps/rear defogger electrical connectors.
  15. Install the radio/HVAC controller cover by pushing in at the clip locations.
  16. Install and lock the push pin fasteners.
  17. Connect the negative battery cable.
Oct 26, 2010 | 1998 Saturn SL
I replaced the hub assembly on my 96 Cadillac Deville. No problems with the install. Now the traction control and ABS lights come on and it sounds like the front end does not run smooth. (Traction...
You torqued the axle nut to the proper spec?
The ABS harness from the new wheel bearing is in the correct clock position?
Are you sure one of the pins in the connector isn't bent? Look carefully in the sensor side of the connector. The male pins are very small and easily bend.
Check the harness on the car side of the connector. It is very common for the harness to break or corrode especially near the connector or anywhere along the harness where it routes through the wheel well area.
Oct 12, 2010 | 1996 Cadillac DeVille
Where is neutral safty switch on 83 camaro z/28
Neutral Park/BackUp Lights Switch - REPLACEMENT & ADJUSTMENT
  1. Remove the console trim from the console.
  2. Disconnect the electrical connector from the switch.
  3. Remove the 2 attaching screws from the switch and remove the switch.
  1. To install a new switch:
    1. Place the switch onto the transmission control shifter and loosely install the attaching screws. Position the transmission control shifter assembly in the N notch in the detent plate.
    2. Assemble the switch to the transmission control shifter assembly by inserting the carrier tang into the hole in the shifter lever.
    3. Install the attaching screws and tighten.
    4. Move the transmission control shifter assembly out of N position. This will shear the switch internal plastic pin.
  2. To install the original switch:
    2. Rotate the switch on the shifter assembly to align the service adjustment hole with the carrier tang hole. Insert a 3 / 32 in. (2.38mm) diameter gauge pin to a depth of 9 / 16 in. (15mm) and tighten attaching screws.
    3. Remove the gauge pin.
  3. Connect the electrical connector to the switch.
  4. Install the console trim to the console.
Fig. 1: Neutral start/back-up light switch
Hope this helps (remember to rate and comment this).
Sep 25, 2010 | 1983 Chevrolet Camaro
Trying to control Zenith DTT900 box with Yamaha RX-V463 remote
Since Insignia and LG share compatible codes for digital-to-analog converters, review your remote control's manual for LG VCR codes as they should work to control the Insignia converter.
Feb 26, 2010 | Yamaha RX-V463 Receiver
Westinghouse LF708C fault code SE. not spinning. what needs to be fixed?
SE refers to a sensor error, remedies include checking all connections plugs: § The connector (5pin, male, white) in the Wire Harness is not connected to the connector (5 pin, female) of Hall Sensor in the MOTOR. ?_? reconnect or repair the contact in the connector The electric contact between the connectors (5 pin, male in the Wire Harness and 5 pin female in the Hall Sensor) is bad or unstable. ?_ Reconnect or repair the contact in the connector ? The connector (6 pin, male, natural) in the Wire Harness is not connected to the connector (6 pin, female, natural) of PWB ASSY(Main) or the electric contact of connectors is bad/unstable. ?_ Reconnect or repair the contact in the connector ? The electric contact between the connectors ¡a6 pin, male in the Wire Harness and 6 pin female in the controller(Main)¡bis bad or unstable. ?_ Reconnect or repair the contact in the connector ? The Wire Harness between Hall Sensor in the MOTOR and PWB ASSY(Main) is cut(open circuited). ?_ Repair/replace the damaged WIRE HARNESS ? The Hall Sensor is out of order/defective. ?_ Replace the Motor ? The controller(Main) is out of order/defective. ?_ Replace the PWB ASSY(Main)
Jan 22, 2010 | Westinghouse Washing Machines
Battery would not charge while bike is running.
u sure the alternator is producing-hows the wire connections to batery-inspec fuses n other partz of harness
Aug 24, 2009 | 2002 Yamaha YZF-R6
Clymer Marine Maintenance and Repair Manual '99 '02 Yamaha 115 250 HP 2 stroke Outboards Logo
354 people viewed this question
Top Clymer Boating Experts
Fabrice Wolters
Colin Stickland
Colin Stickland
Steve
Steve
Are you a Clymer Boating Expert? Answer questions, earn points and help others
