Question about Admiral Washing Machines
My washer take water but not continue. is the Admiral Model, this machine use board W10296024. I observated that the door is not locket when finish take water
    Novelist:
  • 112 Answers
The washer will not wash unless the door is locked. Check the latch and make sure the safety interlock switch is not broken. This switch will only make contact if door is fully closed.
Posted on Jan 04, 2017
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
HOW fix myadmiral washer model AED4475tq0
check the clutch may be slipping and for good measure check the door switch with multi meter for continuity
Jan 14, 2015 | Admiral Washing Machines
W6444
make this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 25, 2013 | Washing Machines
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 21, 2013 | Kenmore Washing Machines
The washer work but stop along the way,ie unable to complete the circle
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Affinity stops in the middle of a cycle a just shuts off no signal or anything?
use the following steps. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
May 23, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer heavy duty cycle issue
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
My admiral washer Model #lnc 676OB71 continues to let water run in the machine even with the cycle dial turned to off. What is going on? The lid can be closed or open.
If the water continues to run, even when power is off at the wall switch it's likely that the water inlet valve has failed...When power is cut they should shut off!..Replacing the inlet valve is a simple and common job...Good luck....Nomess
May 21, 2010 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
