Question about Singer Sewing Machines
I need to know the settings on the Singer 258 for using the buttonholer attachment.
I haven't used my machine in quite some time as it needed repair and now it is working again. I have a rush job I need to finish and I just need to do 2 buttonholes. I have the machine all set up with the attachment but for the life of me I can;t remember what the settings should be!!!
2 Suggested Answers
  • 1788 Answers
SOURCE: trying to make a buttonhole
One thing to try is that the button hole lever has not moved to the front or back of the guide, make sure that it is in the direct middle. Sometimes they get moved when you take out or insert fabric. If, that is not it, call Singer and find out if there is a problem with this model, because if it is maybe you can exchange it. Their phone number, 1-800-4singer
Posted on Jan 05, 2011
Which model old style cam type buttonhole attachment from Singer will fit on the Bernina 807 minimatic machine that is an equivalent to the singer featherweight that I can make keyhole buttonholes.
In my earlier response, you need a shank that is made for your Bernina 807 and Berninas made in that era. Only "Old Style" Bernina presser feet and adapters will fit your machine. No other brand will work, not Singer, not Janome, not Brother, nothing but Bernina Old Style. There are several Bernina old style presser feet. Look for presser feet with the number printed in black ink or presser feet that have the number stamped into the metal. Do not buy a Bernina presser foot with red numbers--will fit only newer Bernina machines.
If you want to use the Singer buttonholer attachment, it needs to be for a straight shank machine. You will need to have a Bernina shank adapter for your machine.
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." The first Old Style item is the shank adapter you would need to attach the Singer buttonholer attachment to your machine. (Am assuming it will work, no guarantees!) If it doesn't work, then you will probably not be able to use the Singer buttonholer with your Bernina machine.
This shank adapter would fit your machine:
If you are looking for a snap-on adapter, it needs to state that it will work with a Bernina Old Style machine, ie the old Record machines (930 Record, 830 Record, 730 Record, 707, 807 Mini, 630 Record, and 530 Record--or in other words, Berninas manufactured prior to probably 1996).
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." If you are looking for the snap-on, go to the very last item on the page (Old Style). This will fit your machine. Remember, if it says Old Style, it should work on your machine.
This snap-on shank will fit your machine:
Presser Foot SNAP ON SHANK Adapter Bernina Old Style 530 532 1630...
This presser foot will fit your machine:
This is an entire kit of snap-on feet with shank (included) that will work on your machine:
Here is a kit of snap-on feet with shank (included) as well as the buttonhole attachment you were asking about:
17 Feet Set for Bernina Sewing Machine Old Style eBay
Although, I believe you will be able to make only straight buttonholes with this buttonhole attachment.
Hope this helps.
Jan 07, 2017 | Singer Sewing Machines
What model singer buttonhole attachment will fit a Bernina 807 minimatic machine. This question was asked but I can't find the answer.
Most likely a Singer presser foot will not attach to your Bernina. They are not interchangeable.
You can also probably use something like this:
but you need to purchase a snap-on shank adapter for your Bernina, like this:
Or, are you talking about the presser foot? Bernina #033? You can usually find a replacement through eBay, or even purchase a snap-on shank and pick up a snap-on buttonhole foot. But, if you have another zig-zag foot or open-toe presser foot, you can probably get by with using it as long as you can see your marks on the fabric when you stitch.
If you are actually referring to a buttonhole attachment like what is available for new machines, you may be out of luck. Probably not any available for this older model. The automatic buttonhole attachment usually has a sensor that your machine does not accommodate and the buttonhole attachments have a different shank that will not work on the older machines.
However, the buttonhole dial on your machine should work just fine. You just need to do more pre-work, ie measuring the button and marking the buttonholes on the fabric before stitching them. Even if the machine is only a zig-zag, buttonholes can still be done on them. Just be sure to practice a few buttonholes on scrap fabric before trying them on your garment. Get the stitch length so the zig-zag stitch has no gaps between threads but also does not overlap the thread next to it. Also, check that the tension does not cause the fabric to pucker (be sure to use a stabilizer between the fabric to prevent the fabric from stretching or distorting).
Button hole MPG (good tutorial)
807 Manual: (pg 27-28)
Tutorial how to sew buttonholes with the BERNINA presser feet no 3 3A 3B...
Genuine Vintage Bernina Old Style Presser Foot 033 Manual Buttonhole eBay
I need to know what the settings need to be on the Kenmore 158 machine to use the buttonholer?
You'll have to provide more information about the sewing machine. 158 indicates the manufacturer. However, there are a lot of Kenmore sewing machines from that manufacturer. The 158.1340 manual is available here: .
Page 40 (41 in the linked format) begins the section on buttonholes. With the buttonhole attachment, you need to set the stitch to the second narrowest zig-zag stitch. You can use any stitch length. The description of using the buttonhole attachment starts on page 45.
Without the buttonhole attachment, you set the stitch selector to each part of the buttonhole as you reach them. The stitch length dial has to be set to an appropriate length in the block for buttonholes. The top and bottom tack bars use the same stitch selector. There are separate ones for the left and right sides of the button hole.
I hope this helps. Please add a comment with the rest of the model number on your sewing machine for specifics with your machine.
Jan 04, 2017 | Kenmore Sewing Machines
Need instructions for Singer buttonhole attachment 103233.
I found a manual for several Singer Buttonholers here: . I'm not sure of the part number for the Professional Buttonholer Model, which looks like the one for my Singer Touch & Sew. Mine is part #161829 (if I read the box correctly).
I hope these help.
Feb 06, 2016 | Singer Sewing Machines
How can I make buttonholes on this machine?
In addition to using the attachment, there are several other steps that have to be made on your machine. For instance, on some you have to pull down a lever; on others you have to set a dial, and sometimes you have to do both. That's why your attachment alone is not working; it's designed to work WITH other settings. You can get a free user's manual at, and for heaven's sake, use it as your bible!
Oct 10, 2014 | Singer 7258 Sewing Machine
How to use buttonhole attachment on Singer Simple Sewing Machine
"Read your manual for settings, if you cannot find it go to their website singerco,com and download for free
Apr 17, 2010 | Singer 3116 Simple
How can I obtain a copy of ''Instructions for Using Singer Buttonholer #1605060''?
Hi. Is this for a Singer Featherweight sewing machine? If so, I can scan mine and email it to you. These attachments make the best buttonholes in the world!!
Just let me know, ok?
Happy Sewing!
Mar 03, 2010 | Singer Sewing Machines
I have a singer machine model no 4830C, can u explain to me how to do buttonholes, do i need to make the holes first or how it has to be done.
If you can't get the hank of using that buttonhole foot and attachment, go to your stitch length dail turn dail to red #1 this will make the right side of your buttonhole(the length) If you move the dail following number sequin 2-4 this will give you beautiful buttonhole without using that attachment. Remember that you don't move your fabric let the machine do its job, just check to make sure that it is lined up . Practice very easy. I use this machine for anything I sew. Love it.
Mar 03, 2009 | Singer 132QRFB Mechanical Sewing Machine
Auto buttonholer problem singer 2662
You do need to adjust your stitch length to get the satin stitch look. Also, some of the auto buttonholers require you to reset the lever after each buttonhole to restart it.
Feb 01, 2009 | Singer 2662
The buttonholer doesn't work right.
Most sewing experts will tell you that the best buttonholes are made with the Singer Buttonhole attachment that has been available since the 1930's. It makes perfect buttonholes every time. Everyone complains about the modern machines not making great buttonholes and not working correctly. Just do a quick search on eBay for one of these vintage attachments and your problem is solved once and for all. Don't waste all the time and money trying to get your machine fixed to only find it does not make good buttonholes...the best solution has always been the buttonhole attachments made by Singer, which the professionals use even with modern machines. They can be found in low or slant shank.
Oct 04, 2008 | Singer 2662
Sewing Machines Logo
27 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
