Question about The Watches
How do I open the back of watch to insert new battery.Model No.AA5-OW208. Ser.no P07082 PLU92559
  • The Master
  • 19,110 Answers
You don't. You take it to a local jeweller and they do it for you for $6 to $8 in 5 minutes. They have the tools, the knowledge and a full range of batteries.
Posted on Jan 04, 2017
How to change battery?
Depends on the watch. Do a you tube search how to change battery on a ___________(insert your model)
Dec 01, 2015 | Watches
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    I was just wondering how to remove the back of my watch so I could change the battery? Model AM-4065. Thanks for the help
    To open the back of a Fossil Am-4065 your best bet is to use a watch case opener like this
    You can also use a pair of needle nose pliers, but you then run the risk of damaging your case back. I would advise against it. I've had to deal with quite a few watches that were damaged in such a way.
    The opener has an assortment of small pins. Usually you will be able to find some that will best correspond to the size of the grooves on your watch. Then the case opener can be adjusted so that the pins are securely fitted to the grooves so that you can then turn the case back off.
    You will need to hold your watch securely while turning the opener, or it may slip out of the grooves and damage your case back. This is not a difficult task, you just have to go slow and carefully.
    After you do so you should be able to carefully pop the battery out. Do not use a small screwdriver or other metal tool to do so. It can damage your watch. You can usually use your fingernail. After you do so you can simply read the battery number off and find a replacement. Many grocery store/drug stores and Radio Shack carry an assortment of watch batteries. You can also go to a website like Battery Bob and order the battery, but for one battery it may not be worth it.
    Your watch will not have the same water resistance after you open it. Usually a watch like this will at least have it's case gasket lightly wiped with silicone grease before it's re-closed (or have the gasket/O-ring replaced and treated with grease). This should not be a problem if you don't swim or bathe with your watch on.
    Feb 28, 2011 | Watches
    How do you change the battery in a black dice flow watch
    You need to open watch case back using appropriate tools. There are two batteries in this model - one for each watch movement. Unscrew/un-clip battery contact. Memorize polarity (+ and -). Take the battery to your nearest watch battery shop or watch repair shop and buy the same one. Fit new battery back in watch (remember polarity!). Fit back contact as it was. Close the watch case back. Set the time. Done.
    Feb 25, 2011 | Black Dice Industries BD04101 Flow From...
    Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    I have a Majestron quartz pocket watch. How do I replace the battery?
  • Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
  • Remove the circular watch battery out of the back of the watch.
  • Take the battery to any department store or watch store and purchase a new replacement battery.
  • Insert the new battery into the back of the watch.
  • Screw on or push on the back of the watch. Set the watch to the correct time.
  • Aug 23, 2010 | Watches
    How to open the back of Kenneth Cole KC3434 watch to change the battery?
    BASIC WATCH BATTERY CHANGE
    Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
    Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
    Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
    Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
    Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
    Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
    If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
    Best regards.
    Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
    Seiko watch ser#687612,need a new battery,need to know which one
    Hi there, can you look on the back of the watch for the model number. It should be similar to 7T62-0AC0 - I can then tell you which battery you require -
    May 11, 2010 | Seiko SNA413 Wrist Watch
    Timex Men's Digital Expedition Chrono Alarm Timer Watch battery
    hi
    please follow the steps to change the battery
    1. Step 1 Make sure the little arrow on the back is aimed to the right. Then, insert a small flat head screwdriver into the notch on the edge, and lever the back open. Place the back to one side.
    2. Step 2 Unscrew the clip holding the battery (if your model has a clip), and remove the battery.
    3. Step 3 Use plastic tweezers to put in a new battery. Do not directly touch the new battery. Screw the clip (if it has one) back on.
    4. Step 4 Replace the gasket that seals the watch. Then lightly coat the gasket with a silicone-based grease.
    5. Step 5 Align the back with the little arrow aimed to the right again, then carefully press the watch between two pieces of wood that are being held by a small vise, until the back seats itself.
    thank you....
    Apr 08, 2009 | Timex T41091 Expedition Watch
    My watch needs a new battery.
    There is a tool that you need that adjusts to the three holes or openings in the back of your watch and it just screws off. If you don't have access to the tool, simply take two push pins and CAREFULLY insert them into the openings and unscrew the back cover. Remember that it unscrews counter-clockwise.This will give you access to the battery simply take it out and go to the store to buy a replacement repeat the process to install the cover back on.
    Nov 10, 2008 | Swiss Army Wenger Sportedge Bracelet Watch
    Watches Logo
    14 people viewed this question
    Top The Watches Experts
    D. E. Hev
    John mullen
    vince
    Are you a The Watch Expert? Answer questions, earn points and help others
