Question about Whirlpool Dishwashers
Our Whirlpool dishwasher (model # DU943PWKSO) stopped working. Before after closing the door, the panel lights up & we select the setting. But now there is no light and it won't start. Thanks!
markevans
  • 148 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Posted on Dec 28, 2007
SOURCE: Whirlpool dishwasher model DU920PFGB4 will not start.
my dishwasher is only 2years old and will not start. the lights on the panel come on but wont start.
Posted on Sep 26, 2009
rylee_smith
  • 8619 Answers
SOURCE: DU943PWKSO DISHWASHER STOPPED WORKING, ELECTRICAL
Hi
Thanks for using FixYa. This issue can be either due to a faulty door latch or door lock switch which is not engaging itself. And, if the door latch will not engage the dishwasher will sense it as open door and will not start the cycle. And the sound might be coming from the door lock solenoid (a hum/buzz sound).
The light also blinks when the dishwasher detects a no-fill condition. You’ll need to get access to the fill valve by removing left panel, look at back to see where valve is when you get to it remove one of the wires and set meter to ohms setting and put a lead on each tag on valve. The reading you should be about 3.6k ohm if you don’t get a reading then the valve is at fault. I'll also suggest you to check the detergent dispenser solenoid for this issue. Remove the door panel and see if there is a round item at the dispenser assembly with two wires attached to it. Put the dishwasher into a cycle and when the noise appears, gently press on the solenoid to see if that is where the noise is coming from.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Mar 30, 2010
rylee_smith
  • 8619 Answers
SOURCE: Whirlpool dishwasher model DU920PFGGO wont start.
Hi
Thanks for using FixYa. To unlock it press and hold the AIR DRY button for 10-15 seconds. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 08, 2010
rickead1
  • 1998 Answers
SOURCE: why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Posted on Nov 17, 2011
Testimonial: "Rick Ead's rapid response led to a solution within an hour. His suggestions were correct and after figuring out the button combination for out particular machine we were up and running."
Model #DU1015XTXS2
With the dishwasher door closed and the unit in standby mode or with no cycle selected and all lights off, press - heated-dry, normal, heated-dry, normal buttons in that sequence. Then press cancel..... wait until 2 minute cycle is done. Open and close the door and make sure it is closed. Then run another cycle.
Apr 06, 2014 | Whirlpool Dishwashers
DU943PWKSO DISHWASHER STOPPED WORKING, ELECTRICAL CURRENT TO PANEL...THE LOCK LIGHT COMES ON WHEN THE DOOR IS CLOSED AND LATCHED, BUT THE WASHER WON'T START WHEN ANY OF THE BUTTONS ARE PUSHED...THE LOCKED...
Hi
Thanks
Rylee
Mar 30, 2010 | Whirlpool DU943PWK - Multiple Color...
DU943PWKSO DISHWASHER STOPPED WORKING, ELECTRICAL CURRENT TO PANEL BUT DOES NOT START NOR DOES ANYTHING TURN ON. LAST YEAR HAD THE SAME PROBLEM TECH TOOK FRONT APPART AND THE DISHWASHER STARTED WORKING. I...
Check you electrical power box that feeds to the house. If this dishwasher is hooked up under a sink counter and there is a garbage disposal in the sink area the dishwasher should be hooked up to the same circuit that the dishwasher is hooked to. If the garbage disposal works then the circuit is good your problem is either in the connection from the plug to the dishwasher or in the timer section of the unit. Either way the unit wont operate. Check power into the unit then check power at the hookup from the dishwasher to the plug itself if all is good then timer has gone bad
Good luck hope this helped you some
Dave
Jan 28, 2010 | Whirlpool DU943PWK - Multiple Color...
''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Mar 26, 2009 | Dishwashers
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Nov 03, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher stopped mid programme
First place I would go is the door switches, make sure the dor switch assembly is not broken, and switches working.
Jan 05, 2008 | Dishwashers
Whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Nov 17, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
