Question about Philips 42PF7421D 32 in. LCD HDTV
Clear picture. goes to snow in3 to 5 minutes. green line to
  • Philips Master
  • 6,694 Answers
The TCON board or the LCD panel is faulty. Can conform by replacing the TCON board .
If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Jan 04, 2017
Philips TV model no.42PF7421D/37 has green line on left and clear picture goes to snow in 3 to 5 minutes
the tcon boar or the lcd panel is faulty. can confirm by replacing the tcon board .
Jan 04, 2017 | Philips 42PF7421D 32 in. LCD HDTV
Acer lcd tv screen goes fluro green, only on some pixels not entire picture but rest of screen is not a very clear picture.
my acer lcd 32" tv just recently went of the blink. It has vertical, horizontal lines and fluro green screen. please need some advice...
Dec 30, 2009 | Acer AL1716WAB LCD Monitor
CT-36SL14 powers on with clicking noise.
Sorry, but you've been had. From what you describe, it sounds like the set is going into high voltage shutdown. It does this if picture tube voltage goes over limits that might cause excess x-ray radiation, and the only way to clear the shutdown is to unplug the set. A number of things might be causing the problem, including a bad picture tube which would exceed the cost of a new TV. Without checking the set myself I couldn't suggest anything specific, and there are few repairs you would be able to try for yourself without the tools and some experience.
The only "solution" to this, I think, is to try to get your money back from the seller as the item was misrepresented, and apply it toward a set you can see working before you buy it.
Dec 07, 2008 | Panasonic CT-36SL14 36" TV
42EDT41 colored snow/pixels
I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
Thanks a bunch in advance...
Oct 22, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Diagonal green lines on a green screen
It is possible that the electron-gun inside of the CRT is having an intermittant short. It is also possible that there is an intermitttant failure in the bias or drive circuits for the CRT electron-gun.
The TV service tech would have to run some tests to determine the actual fault, and then the failed components.
If the CRT is at fault, the set will not be worth to service.
Jerry G.
Apr 25, 2008 | Televison & Video
Green and red snow
I had the same problem with Red/Green snow after 11mos of owning my Plasma. It was coevered under warranty thank goodness. The repair person had to replace all the inside circuit boards to fix.
Apr 02, 2008 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Picture clarity
Sounds heat circuit related, and if under warranty you should notify them before you have to pay for the tuner or sync board.
Feb 03, 2008 | Westinghouse LTV-37WI 37 in. LCD...
Picture Problems
Here is how my picture looks like. It only happens on analog channel and digital channel is clear like picture-in-picture.
Jan 25, 2008 | Samsung HL-R4667W Rear Projection...
Philips 42PF7421D 32 in. LCD HDTV Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
