Question about GE (GTS16BBS) Top Freezer Refrigerator
Freezer door pops open when close fridge
I have an Amana atb1836ar top freezer fridge. The freezer has begun to pop open when I close the fridge. Worse yet, sometimes when I open the freezer door, there is no pull, as if the gasket is not working. This happens soon after opening the fridge as well as hours after opening the fridge. At time of purchase, I bought an extended GE-Zurich warranty. When the A&E warranty service guy paid a visit, he said it was "normal." I don't buy it, especially when the unit did not do this the first three years I owned it. If this is normal, then what a huge energy-waster. If the GE-Zurich Warranty will not fix it, I'll boycott and badmouth both GE and Amana/Maytag.
  • 227 Answers
There are a few things you could try. Make sure both the gasket and the area around the opening that the gasket rests on are clean dry and not iced over. Make sure your fridge is level. If those do not work you may need a new gasket. One thing is for sure it is Not normal. You could also try contactging a supervisor at A&E and explain what happened. You may have got a repairman who was having a bad day or just plain lazy! Good Luck!
Posted on Jul 21, 2009
I have a KitchenAid Superba model KSCS250FAL00 is not cold especially at the top part of both the freezer and the fridge. I could not feel any air from the vent on top left in the fridge side and I see...
This could be the flap in the freezer compartment is stuck closed or indeed the fan has gone o/c, if the fan can be heard running when the door is closed it will more than likely be the ducting flap
Apr 10, 2014 | Amana ATB1836AR Top Freezer Refrigerator
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
My amana bottom freeze refridgerator door in opening a little when the top door is closed. do i need to adjust the screws or is it something with the seal?
raise the front legs so the machine is tilted back a little,this will help the top door close easier,also most likely you have nothing heavy on the door itself,all a fridge does is move air,the evaporator coil gets cold and the evap. fan blows cold air from the freezer into the fridge side and the air keeps circulating,when you shut the top door it's pushing the air down into the freezer and popping the door open,like i said raise the front legs a little and put stuff on the freezer door so it has some wieght to it and it won't pop open.hope this helps salde
Jul 24, 2012 | Refrigerators
when you close the fridge door you create pressure in the fridge and the freezer door may pop open, close it more softly. or there may be stuff pushing against the inside of the freezer door
Mar 05, 2012 | Maytag Refrigerators
After you open and close the refrigerator on top, the freezer drawer pops open. it is now leaking water.
check to see if the fridge is tilted back a little so the top door closes with just a little shove,also if there isn't any weight on the freezer door it will pop open,put something on the door,a bottle of water that will freeze or whatever you want,it could be leaking from stuff melting from the door being open, is the water dripping from the door?the door does freeze up and will melt out if door is left open, hopefully your air ducts didin't freeze up,make sure you can feel cold air blowing into the fridge section,if not heat up the back wall where the evap fan motor is with a hair dryer the air ducts are near there and check the freezer ceiling for frozen water droplets,hopefully everything will freeze back up with the door closed.
Jan 28, 2010 | Amana ABB1927DE Bottom Freezer...
The freezer is not freezing its cold and the
hi thiers no problem in freezer you have 2 chect the compressor which is used 2 produces the cool gas to the freezer
Sep 14, 2009 | Amana ATB1836AR Top Freezer Refrigerator
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Top freezer door pops slightly open when frig door is closed
try to adjust hinges and check the door gaskets for pinching. Also I have seen that if the fridge is slightly pitched forward and not slightly towards the back gravity sometimes this causes the problem you describe.
Apr 26, 2009 | GE Refrigerators
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Jan 23, 2009 | Amana ABB1927DE Bottom Freezer...
GE (GTS16BBS) Top Freezer Refrigerator Logo
152 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
