I noticed one of your posted answers and hope you can assist with this one. Our whirlpool washer functions, but during spins it has a rubbing noise that just started yesterday. Water pumps out, agitates normaly, spins at regular speed, but it has this new noise and I dont want to wait for it to break completely. (the pump has recently started cavitating.) Any suggestions?
  • tbigits Jul 21, 2009
    Top loading Whirlpool Model number LSR8010PQ0
    tried to turn the drum by hand, but it is very resistant. Rubbign sound is similar to a wire brush on metal, which makes me think berring. Seams that when teh spin cycle first starts turning it is relatively quite but quickly gets intense. Would this help to narrow it down? If it is a bearing would you have a set of instructions for replacement?
  • 15,935 Answers
Is this top loading or front loading?
Brand & model # are also helpful.
Thanks!!
Posted on Jul 21, 2009
  • 2 more comments
  • blueextc3221
    blueextc3221 Jul 21, 2009
    If there is no clunking or banging going on - your shaft bearing has failed, the brake spring is broken, or the transmission gearing is shot. The pump could be on its last legs too - if you know it is cavitating.
    Cavitation occurs with the introduction of air into the system. Check your hoses for cracking - and your inlet strainers (where the hoses hook the the machine) for buildup and debris. It may be causing a flow problem.
    This is a direct drive model, so no belts or pulleys to be concerned with making the noise.
    CLICK HERE for all the expanded diagrams of your washer.
    THIS ONE in particular shows the transmission and brake assembly.
    I would suggest getting an in-person diagnosis instead of throwing money blindly at the machine.
    If you require more help - just let me know.
    Thanks
    :D
  • blueextc3221
    try turning the drum by hand. can you hear any crunching noises - or the noise you hear when the washer is spinning??
  • blueextc3221
    Checking for rubbing noises:
    Step 1
    Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
  • Step 2
    Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
  • Step 3
    Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
  • Step 4
    Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
  • Step 5
    Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
  • Step 6
    De-couple and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the pump, it's the motor bearing.
  • blueextc3221
    It will not come with instructions - as the same part fits many washers.
    My suggestion is to disassemble the washer - and make sure the grinding you are hearing is indeed coming from the bearing.
    Take the washer out somewhere with alot of room, and tip it on its back.
    Have someone turn the drum as you listen at the bottom by the pump and motor to try to locate the source.
    It could be as easy as a bobby pin stuck in the pump impeller.
    Listen and feel the transfer case (transmission) and it may be evident the noise is coming from there instead.
    Give it a try - and if you locate the source - I can help you with disassembly & replacement of the bad part..
    Thanks
    Cabrio washer wtw5500xw0 loud spin and grease on floor
    FIXED Cabrio has loud noise during spin - ApplianceBlog
    www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
    Aug 21, 2009 - 10 posts - ‎5 authors
    Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
    How to tell if your bearings are bad on a Whirlpool Cabrio ...
    ? 1:01
    https://www.youtube.com/watch?v=5rHn13lKjzc
    Jan 19, 2012 - Uploaded by RenewAppliance
    http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
    Jan 16, 2016 | Washing Machines
    Noisy during agitate cycle whirlpool washer
    Originally posted as solution to Kenmore 24992300 failure to agitate and loud whirring noise during spin cycle.... Hope this helps:
    The problem as I noticed it was that the washer would start making a super high-pitched and very loud whirring noise during the spin cycle, and that when I would open the lid, the drum would not be spinning, but when I would close the lid, the drum would start spinning. I was okay with this during that load but after reading here and taking it apart, I realized what had happened:
    The agitator dogs are supposed to have a 3-toothed profile on each one, but they become worn over time due to being made of a soft plastic. The dogs should "throw out" into an inner ring gear during normal operation, turning the entire drum. But when they became worn enough to slip, they would still throw out, grinding them at very high speed into the inner ring gear. Since they are made of a softer plastic than the gear, they were just getting more and more worn.
    I assume the way this was supposed to fix itself was that when the outer tooth on the dog became worn, the next one would engage, but that didn't happen.
    Because the dogs are made of such a soft plastic, I was able to cut a new tooth profile into each one, so that when they were put back in they would function correctly. It takes very little effort and a few minutes with an x-acto knife to cut the right profile.
    I'm going to buy the replacement dogs, which being a manufacturer substitute will hopefully be made with a better tooth profile, from harder plastic, or both.
    As another note, who knows how long the dogs weren't engaged correctly during agitation, causing clothes to sit without really being washed, but without the high pitched air raid siren. So probably a good idea to replace or repair them immediately, even if you can get it to work intermittently.
    Sep 12, 2013 | Sears Parts Direct Whirlpool 4313896...
    Drum appears to be loose and makes a lot of noise when on the spin cycle
    With the washer empty, spin the wash tub by hand. The drum should be spin true without any noticeable wobbling and spin without much noise. If it wobbles or makes any kind of rubbing or banging noise as you turn it by hand. The problem is that the spider support arms are broken. It is an expensive repair job since the washer has to be completely torn apart and the wash drum needs to be replaced. Get a few estimates before deciding whether to repair or replace. Sorry.
    Mar 08, 2011 | Whirlpool AWM6100 Front Load Washer
    My Duet Washer by Whirlpool is about 6 years old and it started making a loud noise during spin leaving shredded plastic in tub. In talking to the repairman, he said if the arms are broken, they would...
    i just had my washer do this to me last weekend. In the final spin out it made a loud noise and i noticed that the plastic between the metal tub and the outer plastic tub was rubbing away.I'm going to tear into it my self being that its out of warranty. Mine is about 6 years old too.
    Nov 19, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
    Loud noise during spin cycle, finding shreded plastic in drum.
    Sounds like the support arms have failed and the wash drum is now rubbing against the outer tub. It is a expensive repair. Get a few estimates before deciding whether to repair or to replace. Hope this helps.
    Nov 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool washer functions, but rubbing noise during spins
    The pump will make a sort of cyclic "creaking" noise just before it goes bad. You might want to remove the back panel and inspect the drive belt, make certain there are no knicks, loose pieces of rubber or it is slipping.
    Let me know.
    Regards,
    Jul 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Noise when stopping after spin cycle or open lid (after moving)
    check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
    Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
    Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
    Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
    Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
