How do you feed the tape when Replacing cartridge
Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
Color ink cartridge needs replacing, but this is a new one
Make sure that there is no tape left on the strip where the ink feeds.
A different solution might be to take a paper towel and dab at the area where the ink exits. make sure you see ink on the towel, and when you do, stop dabbing. If you press it too much you risk losing a ton of ink.
Jul 11, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
BROTHER P-TOUCH 1100
My Brother p-touch 1100 is feeding the white tape through but not printing black ink on it.  It has a new cartridge.  Can anyone help please?
Jun 19, 2008 | Brother P-Touch (PT1100SBVP) Label...
Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
May 19, 2008 | Lexmark Wheelwriter 15 Series II...
Print Problem?
There are two small "hooks" that feed the tape through on the tape cartridge. Make sure the tape is fed through both hooks.
Jan 15, 2008 | Dymo LetraTag QX50 Thermal Label Printer
Disc Feeding Problem
I am assuming you are using a PF-2 printer. If you are using a standard HP78 ink cartridge instead of the Microboards cartridge, the unit will only print approx 5 discs before it stops. The microboards cartridges have a security tag under the barcode label that is scanned by a magnetic reader on the left hand part of the unit. If you are careful, you can use a razor blade and remove the label from a microboards cartridge and tape it on the front of a HP ink and save yourself about $25 an ink cartridge...
Nov 29, 2007 | MicroBoards PF-2 InkJet Printer
Labeling system trouble-shooting
I thought the PT65 took a thermal tape that didn't have an ink ribbon. Compare the part number on the tape cassette with the list of compatible types listed in the labeller's instruction manual. Believe the only compatible cartridges are: M-Knnn/B, where NNN is one of 221, 222, 223, 231, 232, 233, 521, 531, 621 or 631, or M-K221S/B or M-K231S/B A.
Feb 10, 2007 | Brother PT-65 Personal P-Touch Electronic...
k24674
jasbo
jasbo
