TRYING TO FIND A NEW BOARD FOR A LG WINDOW UNIT. THE BOARD HAS THESE NUMBERS ON IT PWB: EAX65585701 AND ASM: EBA77963801. CAN NOT FIND A MATCH ANYWHERE, CAN SOMEONE HELP?
4 Suggested Answers
pnevai
  • 48 Answers
SOURCE: no picture
send an email with the schematic and I'll try to point you in the right direction.
Posted on Jun 29, 2007
mohammed387
  • 1952 Answers
SOURCE: DP14G BOARD
click this link
bumblebeestoves.com/484.html - 92k
thanks for fixya
Posted on Sep 25, 2008
ladywinn
  • 5138 Answers
SOURCE: LG 42PC3RV-ZJ PSU part numbers
Go to Shopjimmy.com and type in your Model Number.
Posted on Oct 09, 2012
How can i fix error e7-90 in sharp ar m351u?
E7-90: Communication trouble (ICU detection) between ICU and PCU (when the scanner is installed)
Cause:
- Defective connection of slave unit PWB connector
- Defective harness between slave unit PWB and ICU PWB
- Slave unit PWB mother board connector pin breakage
Check & Remedy:
- Check connector and harness of slave unit PWB and ICU PWB
- Check grounding of machine.
http://olsonbros.com/sharp/support/pdf_trbl/trbl-arm351u_m355u_m451u_m455u.pdf
Jun 01, 2015 | Sharp Office Equipment & Supplies
Error codes
Content - ICU communication trouble (PCU
detection)
Detail - Communication setup
error/framing/parity/protocol error
Cause - Slave unit PWB connector improper
connection
Slave unit PWB - ICU PWB harness
trouble
pin breakage
Check and remedy
Check the slave unit PWB and the ICU
PWB connector connection.
Check the copier earth
Jul 25, 2013 | Sharp AR-M450N Copier
What is err0r code E 7 02 IN ARM 450 COPIER
The E7-02 means the beam detect sensor never received a beam from the laser. As the previous poster stated you'll need a new laser unit. Meaning that you need to change the whole laser unit but not the polygon motor.
E7 02 Content Laser trouble
Detail BD signal from LSU is kept OFF, or ON.
Cause The connector of LSU or the harness in LSU
is disconnected or broken.
The polygon motor does not rotate normally.
The laser home position sensor in LSU is
shifted.
The proper voltage is not supplied to the
power line for laser.
Laser emitting diode trouble
PCU PWB trouble
Controller PWB trouble
Check and
remedy
Check for disconnection of the LSU
connector.
Use DIAG (SIM 61-1) to check LSU
operation.
Check that the polygon motor rotates
normally or not.
Check light emission of laser emitting diode.
Replace the LSU unit.
Replace the PCU PWB.
Replace the Controller PWB.
Mar 15, 2010 | Toshiba E-STUDIO 650 Copier
Display scrambled on my model # LMVM2055ST
HI. this LCD is attached to the PWB assembly board. Unfortunately, this lcd is not sold separately and, you will need to replace the whole PWB assembly in order to fix this issue.This is actually a pwb(pcb) assembly failure.
CLICK HERE TO ORDER YOUR NEW PWB ASSEMBLY(LCD)
Jun 04, 2009 | LG Microwave Ovens
Not cleaning on top rack. Pump, fill tube asm. & spray clean. Has any seen if this issue could be the deverter motor in the pump or the control board?
Just to review, the LG dishwasher family, including the LDS5811 has the Verio motor and the check valve that diverts water from the bottom rack to the top rack.
If the valve is blocked/jammed, this would cause the symptom you describe. The valve is visible from inside the DW after you open it up.
It is also possible that this motor has failed.
Apr 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Will not start
circut board has a short by the sounds of the system. This board is located in a box right behind the control panel
Apr 15, 2009 | LG LWHD1200FR Wall/Window Air Conditioner
Finding part
eBAY 6870QYE007G LG ELECTRONICS PWB (PCB) ASSEMBLY,
Oct 02, 2008 | iLO Televison & Video
13 people viewed this question
jasbo
jasbo
