How do you get access to the outside of the drum as a spoon was put in the detergent spot and fell into the washer. You can hear it grinding when the drum rolls over. I need to get access
onthejob5130
  • 640 Answers
SOURCE: Detergent drawer will not close and washer will not run.
pull draw out on right hand side fron you will see a little square recess,,,there a sensor on the in side of the main control,,if you cant seem to place take another magnet and place it on the side of control..and thats where to put the magnet
Posted on Jan 03, 2009
buffalonyman
  • 1865 Answers
SOURCE: Cant figure out where to put the laundry detergent in the maytag
This link will take you to the manual for your washer. Page 6 discusses where to add soaps and softners
http://shared.whirlpoolcorp.com/assets/pdfs/literature/6_2727060.PDF
Posted on Jun 02, 2009
SOURCE: LG front load washer A coin fell in between
Hi Echucaellect,
Thanks for the insight. I have a Samsung front loader washer, and have the same problem. Can you tell me how I can fix and retreave the quarter/coin?
Thanks,
Posted on Sep 14, 2009
Macmarkus
  • 2605 Answers
SOURCE: water is outside of drum
Hi, What you speak of is actually a good thing and would be a concern if you didn't hear it. It is not water, but actually a liquid solution used as a counter-wieght to off-set your clothing so the unit can reach a proper balance easier. Hope that help's qwell your concern and answer your inquiry. Please take a second and rate this info provided to you by me here at fixya. Thank you for using fixya & good luck. macmarkus :)
Posted on Dec 07, 2009
Daniel S
  • 4323 Answers
SOURCE: I have Hobart under counter
Hi
Yes you are right, using too much detergent can cause this issue, use less then half table spoon, if the issue remains then the problem is with the unit not getting enough water or the water pressure is not what is required. You can also try to clean the water inlet valve & check the water line for any clogs. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 08, 2010
Next question, how do I get the slime out of the clothes from washer?
Cleaning the rubber door gasket will not get rid of the slime issue. The slime comes from buildup on the outside of the washer drum. There are two causes for this. First, if you always close the washer door after use, then the moisture inside the drum cannot dissipate and the slime can form. Also, using the wrong type of detergent (or an excessive amount of the correct detergent) can cause the slime. There are front load washer cleaning products that you can purchase and run to clean the slime from the outside of the drum.
Dec 15, 2014 | Washing Machines
Braking results in grinding sound
I suggest you pull rear drums or have someone qualified look at rear brakes. it could of broke a spring or other brake hardware. I suggest stop driveing the car until you can inspect or have the brakes inspected..
Aug 02, 2014 | 1999 Ford Taurus
Maytag bravos MVWB300WQ1 keep getting sd code on ever other wash
The SD error code is caused by using the wrong detergent or excessive amounts of detergent.
To correct the issue: Make sure to use HE detergent. Note: Using Non - HE Detergent will cause oversudsing and can damage the washer. Do not use too much detergent.
Note: If using HE 2x - 5x concentrate detergent, reduce the amount being used. The washer will try to run a mini-clean out cycle using cold water and a 5 minute pause to clear the suds. If this cycle does not clear the display and complete the cycle the clothing may need to be rinsed by hand and then rewashed without detergent.
Feb 18, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
Maytag dryer how do I fix a baffle that fell off
You need to access the drum from its exterior. Then you can screw the baffle back on from the outside of the drum. Please post m/n for access instructions.
May 05, 2009 | Dryers
How do i get into the cabinet to remove an obstruction from outsi
hi from uk if the object sounds as you say between outerdrum and wash drum ? may i suggest you unplug machine and disconnect water supply pipes then remove the rear panel this will give access to the main drain hose from bottom of outer drum which also connects to drain pump this hose is rubber and held usually with circular spring clips each end ? remove hose and you may be lucky the offending item/s?? will be resting hopefully near hole? if you use a piece of wire coat hanger you may /will locate item at the bottom of drum with a little patience? and you never know thge mysterious missing sock ? bra wire/ or the thong ? sure you've heard this b4 ? ps with rear panel off you can also rock the drum and listen for item's location ? and with hose off you can check pump for debri/fluff too hope this helps best wishes
Feb 16, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Water leaks
I had similar issue. Fill tube running from the bottom of detergent tray to the washer drum was plugged.... (by a sock!!!). How did it get there? I'll tell you. You see the drum seal (around the inside of the door) is not a tight seal. You can actually reach up behind it from where it meets the top of the drum. Anyway in my case, a sock made it's way through that seal and outside the drum and into the drum containment vessel. So when the drum spun (to dry the clothes and empty the water) it made a terrible noise. The sock became lodged at the base of the fill tube opening and plugged it thus not allowing any water into the drum. Instead, when filling, the water just flowed out from the bottom of the detergent tray and onto the floor. I hope this helps.
Jan 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Neptune stackable washer...
I went to Sears today and asked!  They said use high efficiency detergent (marked HE on the label) and put it directly in the washer with the clothes.  Mystery solved!
Jul 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore front loader drum grinding
This can be a symptom of drum bearing wear. A quick check for wear is to see if the inner drum moves up and down relative to the fixed outer drum. It should only move a minute amount. If it moves more than a millimeter or two, it is probably worn bearings. Regarding the bad smell - Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and remove out the bad smell. Good luck!
Sep 14, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
