Question about Sony Televison & Video
I accidentally turned off my sound bar How do I find he speaker icon on my Sony tv to turn the sound bar back on
SOURCE: wd 62628 tv
After I reset the system, the Audio menu gave me access to the TV speakers that had been turned off. I turned them on and had to wire audio cabes from my sat box to the component audio in on the TV.
Posted on Sep 29, 2008
  • 39 Answers
SOURCE: Mute is turned on (red x through speaker icon in
right hand click on it the untick the mute box
Posted on Dec 01, 2009
electrotech1
  • 1126 Answers
SOURCE: My son played with the remote and accidentally
You have to go into the menu and go to sound set up and turn the internal speakers on. If that don't fix the audio problem, it is possible the audio processor is locked up. To fix that problem you need to unplug the TV from the wall for 40 MIN, and that will reset the processor back to normal.
Posted on Dec 06, 2010
SD Tech
  • 14553 Answers
SOURCE: It will not recognize my sound bar the section for turn off speakers are grey out and it also doesn't see the sound bar.
If the sound bar is missing and speakers are grayed out--if using a box means a setup option there is causing this.
If in set means a similar issue---most likely is a cable box if used is disabling the sets menu for this.
You may if using a box want to disconnect all connections to the set and unplug both set and box to see if after a wait both will reboot when plugged back in.
As a last resort with the model number call Toshiba customer service.
Posted on Apr 01, 2012
  • 41699 Answers
SOURCE: How do I turn off the tv speakers on a Magnavox LCD 47MF437B/37
That's part of setup. Go back to your setup routine (the menu that displays on the screen) and select SPEAKERS OFF
Posted on Dec 11, 2012
Sound bar
there should be an "auto power" feature that should turn the unit back on once a signal is detected.
Mar 20, 2014 | Samsung HW-D450 Sound Bar
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
How to turn on the sound of LCD sony Ex4,40
go to start and then tipe this in your program bar speakers then you will see icon there you eather drag and drop it on wall paper or just leave it there .
Feb 24, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How do i turn off the sound
You can use the function button in your keyboard + Mute sound button in the top keyboard rows to mute and unmute the sounds.
(fn key + Mute symbol key)
I hope this is helpful to you.
Thanks
Apr 26, 2010 | Dell Inspiron 2200 Notebook
Sony bravia kdl- 4052510 picture but no sound from my dvd player
1 Press volume +/- or Mute 2 If it does not work then check if the 'speaker' is set to 'TV speaker' from the "AV set up" menu in "Settings" 3 Press Menu and select Settings. Go up/down and select Set Up icon.Press enter 4 In AV Set up go to speaker and turn on the TV Speaker. This should solve your problem
Nov 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
The sound on the 2 front speakers and the sub woofer on my Sony STR-DE597 turned off and I can't figure out to turn them back on. I've lost my manuel. When I use the test tone on the remote, only the rear...
First, you can find your manual here:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDE597
You may have accidentally pressed the speaker select button and disabled speaker A (main) and enabled Speaker B or disabled both A and B. Start with page 40 in the manual to select Speaker A.
On the remote, press the "Speakers" button (Off/A/B/A+B) repeatedly until you hear some noise.
May 02, 2009 | Sony STR-DE597 Receiver
Lost all Of my sounds
Did your speakers accidentally get turned off or the sound turned down? Also click on the little speaker icon on the lower right and open it up are all the volumes turned on?
Aug 19, 2008 | Computers & Internet
Computer Sound
ok..go to control panel from start button, settings, and select sound icon..at bottom you can re add that icon to your taskbar..
May 28, 2008 | Gateway GT5032 (827103078121) PC Desktop
No sound,volume bar works
Sounds like it may be something you did. Have you checked to see if you accidentally put the sound on mute? Try hitting the mute button on the remote control. Also, if the TV has the option to turn of internal speakers (which you would likely find in the menu under audio settings if it does) make sure they are turned on. If these checks fail then we have an electronic problem to deal with.
Aug 31, 2006 | Emerson EWC1903 19 in. TV/VCR Combo
Televison & Video Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
