Question about Baby Gear
Upper left: sleep recall - Baby Gear
Sleep mode on every ten min. .i did set times
Go to Control Panel (make sure you set drop-down box in upper right to 'View by: small icons', then choose 'Power Options'. In the left pane, click 'Choose when the computer sleeps', also while you are in there, make sure your Power Button setting is set to 'Shut down', NOT 'Go To Sleep'. Many are set this way from the factory and it can cause major performance issues down the road.
Feb 11, 2014 | Computers & Internet
Tip
How to Change Monitor and Computer Sleep Time in Windows 7 1. Click on the start...
1. Click on the start button, then click on Control Panel
2. Once in Control Panel click on Power Options
3. Click on "Choose when to turn off the display", located in the upper left hand corner
4. Here you can select when the monitor will turn off of ever. Also you can when the computer will sleep as well.
5. After you have made your changes click on "Save Changes"
on Aug 24, 2010 | Computers & Internet
Prostart 6 button in sleep mode
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
Jan 09, 2013 | Computers & Internet
Monitor keeps going to sleep
Windows XP
  1. Go to Start then Control Panel and click on Power Options
  2. On the Power Schemes tab, select Home/Office Desk in the Power Schemes drop-down box
  3. In the box labeled System standby, select Never
  4. Click OK to save your changes.
Windows Vista
  1. Go to start and type in the search box Power Options hit the enter button
  2. On the Left side there is a panel Click Change when the computer sleeps
  3. Click the drop-down box which says Put the computer to sleep and select Never
  4. Click Save changes
Mac OS X
  1. Click on the blue/black apple icon in the upper left corner of your screen, and choose System Preferences
  2. In the Hardware section, select Energy Saver
  3. Make sure the Settings for: drop-down box is set to Power Adapter
  4. On the Sleep tab, move the sliding bar labeled Put the computer to sleep when it is inactive for: to Never
Waiting for your feedback.................Do Reply !!!!!!!!!
Mar 11, 2011 | Computers & Internet
Monitor goes to sleep automatically after few seconds since the computer starts
Windows XP:
Windows vista:
Click Save changes
Mac operating system:
Click on the blue apple icon in the upper left corner of your screen, and choose System Preferences
Aug 21, 2010 | Microsoft Windows Vista Home Premium...
Does Simplicity for Children Alex 4 in 1 Sleep System 8664 Crib have a recall
Its my understanding they have all been recalled and Simplicity has closed their business due to everything being recalled. You can not get thru to their number or website anymore.
Apr 30, 2010 | Simplicity for Children Alex 4 in 1 Sleep...
I need help finding the code for my tv. i have a Philmore universal remote pm-rc13. My t.v is a white-westinghouse
Here is the code for your TV 0154 along with the advanced codes.
Advanced Codes for TV_0154TVs ------------------ <TV Group>
0154 244 ACM 165 Fine Tune Up 251 SAP 167 Surround Mute
244 Auto Chroma 244 MTC 231 Speaker In 168 Surround Vol dwn
251 Bilngual 234 PIP Location 233 Speaker Out 164 Surround Vol up
169 Fine Tune Do 228 PIP Select 247 Stereo 129 Component 2 (discrete)
TELEVISION. Uses with:
TUNER/CD/TAPE/PHONO/AMP..CDs................AUX2 088
TELEVISION...............TVs..................TV 154
VCR......................VCRs................VCR 047
VCR......................VCRs................VCR 104
On some models,
100|AM/PM|1-- may be 100/Enter;
Func|Sel may be Digicon;
Level Up|R may be Control Right, Level Up/Minute or Menu Up;
Level Dn|L may be Control Left, Level Dn/Hour or Menu Down;
Review|Qck View may be CH Recall or Quick View;
SetTime Fast may be Stereo Matrix;
SetTime Slow may be Time/Day, Set Up, Clear or Menu;
TV/Video/AV may be TV/AV, Video Mode, Input or A/V;
Wide|TV|Loud may be Stereo Matrix, Surround or Mode;
MTC|OBC|Auto may be ACM or Auto Chroma.
181 0...............0 185 1...............1
120 ENTER...........1-- 120 ENTER...........100
183 2...............2 187 3...............3
180 4...............4 184 5...............5
182 6...............6 186 7...............7
053 8...............8 057 9...............9
185 1...............A 123 A/B.............A/V
120 ENTER...........AM/PM 059 CHANNEL DOWN....AM/PM
183 2...............B 187 3...............C
249 RECALL..........CH Recall 059 CHANNEL DOWN....Channel Down
055 CHANNEL UP......Channel Up 122 PROGRAM.........Clear
250 STOP............Control Left 246 PLAY............Control Right
250 STOP............Cursor Down 059 CHANNEL DOWN....Cursor Left
055 CHANNEL UP......Cursor Right 246 PLAY............Cursor Up
180 4...............D 055 CHANNEL UP......Day
184 5...............E 120 ENTER...........Enter
182 6...............F 121 SHIFT STOP......Fine Tune Dwn
117 SHIFT PLAY......Fine Tune Up 248 PAUSE...........Function
186 7...............G 053 8...............H
250 STOP............Hour 057 9...............I
123 A/B.............Input 181 0...............J
059 CHANNEL DOWN....K 250 STOP............Level Down
246 PLAY............Level Up 122 PROGRAM.........Menu
250 STOP............Menu Down 246 PLAY............Menu Up
246 PLAY............Minute 116 SHIFT PAUSE.....Mode
245 MUTE............Mute 230 SHIFT FFD.......PIP Freeze
235 FAST FORWAARD...PIP On/Off 232 SHIFT REW.......PIP Replace
119 POWER...........Power 052 DISPLAY.........Recall
249 RECALL..........Review 248 PAUSE...........Select
122 PROGRAM.........Set Up 118 REWIND..........SetTime Fast
122 PROGRAM.........SetTime Slow 056 SLEEP...........Sleep
116 SHIFT PAUSE.....Stereo Matrix 118 REWIND..........Stereo Matrix
116 SHIFT PAUSE.....Surround 122 PROGRAM.........Time/Day
056 SLEEP...........Timer 181 0...............Timer Set
056 SLEEP...........Timer Start 116 SHIFT PAUSE.....TV
123 A/B.............TV/AV 123 A/B.............Video Mode
058 VOLUME DOWN.....Volume Down 054 VOLUME UP.......Volume Up
116 SHIFT PAUSE.....Wide
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Sep 29, 2009 | Televison & Video
N96 lock code
Have you tried the last four digits of your cell phone number?
The default code is 12345 if you did not change the code in the first place. Some times a good nights sleep or a warm shower might help you recall the new code you don't remember now.
Jun 22, 2009 | Nokia N96 Smartphone
I need upper track (plastic pieces) for my Graco 4 in 1 Sleep System Model 4600CL. There are two lower track pieces, and two upper track pieces. All I need is ONE of the upper tracks. Please help!
I have a Graco 4 in 1 Ultra Sleep System Model 4600 CL. There is a recall on this model for the track guides breaking. The website is www.simplicityforchildren.com You can get a replacement track system for free and you can also order parts at 1-800-858-8323.
I also have the complete instructions for assembly of the crib, toddler bed and day bed.
Jul 06, 2008 | Graco Ultra Deluxe 5-in-1 4605 Crib
Sleep timer will not work
the sleep does not work at all on this remote it is like some kind of recall
Aug 20, 2007 | GE RM24912 Universal Remote Control
Baby Gear Logo
60 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
