Question about Dell Computers & Internet
Trying to start Dell Precision T7400 that won't start but works?
The Dell Precision T7400 only goes pass the opening page. The last place it goes to is "Searching for devices". Last words on the page is "Dell Inc. MPT BOOT ROM SUCCESSFULLY INSTALLED". This became a problem after I factory re-installed. Do I need to load some sort of fixer disk or what?
melnavz
  • 1226 Answers
SOURCE: Dell precision 670
Ok go to bios setup and then "load bios default" and press "F10" to save and exit. i will tell you in case this not work just tell me.
Posted on Jan 18, 2008
frcs68
  • 1605 Answers
SOURCE: Dell Precision 470 Dual Processor
enable "auto" in BIOS for drive #0 and drive #1. you can select IDE or SATA drive. restart the machine.
Posted on Dec 10, 2008
RescueTechLA
  • 2653 Answers
SOURCE: Boot a Sony DVD RW DRU-840A drive in DELL precision 530
Have you tried changing the boot order.
If you're trying to use it as a boot device you need to tell the system to boot the cd /dvd drive FIRST and of course you need to have a bootable cd / dvd in the drive.
Let me know if you're already tried this.
Posted on Mar 04, 2009
  • 23 Answers
SOURCE: Dell Optiplex GX50 won't load windows OS
Which cdrom is it? Is it a windows XP cd? This is an older PC? Does it have a floppy disk drive? Try downloading from Barts a bootable floppy disk, set boot order to floppy in BIOS, change to cdrom drive letter after booting to floppy (D:?)
got to I386 folder and set up from there.
More info would be helpful.
Posted on Jul 09, 2009
  • 83 Answers
SOURCE: Dell Dimension 2400 won't recognize DVD-ROM drive as Boot Device.
Enter the Bios and under System Components find the Boot priority in the Bios and move the drive to the top of the list, also you can press F12 at Start up to select it as well. :)
Posted on Apr 14, 2010
DELL PRECISION T7400 Blue screen apears multiprocerssor configuration not supported
Since the Precision T7400 has 2 CPU sockets, then assuming there are no "beep code errors" and all the diagnostic lights go off and the power light is green then you probably need to go into the BIOS (press "F2" when the Dell logo comes on during start up) and find the setting that enables multiprocessor support and ensure that multiprocessor support is enabled. If it isn't change the setting so that it is, save the changes and reboot. If it is then it sounds as if one of the CPUs is not functioning properly. Please note that for multiple processors to work, they must be exactly the same.
Feb 15, 2014 | Computers & Internet
DELL PRECISION T7400 SECOND CPU NOT SUPPORTED
IF YOU HAVE A PC-Os YOU NEED A SERVER Os.
A PC-LICENSE ONLY GOOD FOR ONE CPU,YOU NEED A
SERVER-Os.I SUGGEST YOU READ SAME ON THE NET ABOUT
IT.
Feb 14, 2014 | Computers & Internet
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
Windows XP fails to shut down properly an hangs with a blank blue screen.
sometimes that can be cured with a disk optimizer routine
try this one and see how it works for you
May 29, 2012 | Dell Precision Workstation T7400 - Energy...
Where to locate Dell t7400 serial no.
It should be in the back or on the side panel of your machine. Go here and see if you can paste it in Click Here input your model information and it will gather and show you where these things are located. John
Apr 19, 2012 | Dell Precision Workstation T7400 PC...
Can a recovery set up H/drive from T 5500 be run on a t7400. would like to just change them over instaed of all data transfer. cheers
you can try it but due to the large difference in Chipsets and system configurations it will most likely blue screen on boot if it boots at all
I would expect you can migrate data but the windows and driver installs will need to be done from scratch
Jun 03, 2011 | Dell Precision T5400/ T5500/ T7400/ T7500...
Nvmini.sys file error screen went blue showing error like non paged sysytem fault.
I sounds like nvmini.sys is a virus or rootkit from what I have just read.
It seems like it is quite tricky to remove. Try searching google for nvmini.sys removal.
If you are not particularly technical, you may be better off paying someone to clean it off for you.
Hope this helps.
May 07, 2011 | Dell Precision Workstation T7400 - Energy...
Dell precision 670
Jan 18, 2008 | Dell Precision Workstation 670 PC Desktop
Computers & Internet Logo
62 people viewed this question
Alun Cox
