My craftman 919176320 want start.i used it the other day and now it want start. outlet works that it is pluged in
Window unit will not power on at all and throws the gfi on the power cord however a lamp pluged in the same out let works fine and the window unit works fine pluged in out in the shed and at the shop I...
If the window unit you are talking about is an air conditionner(sorry, it does not say it in the text), you must remember that an air conditionner needs far more amperage than a light or a freezer or both. Have you tried to plug the window unit alone directly into an outlet and not in a power cord? Let me know if these suggestions helped! Good luck.
May 08, 2013 | Refrigerators
Bose subwoofer has no power when pluged in
Make sure your power outlet and your audio source are ok. If they are then the subwoofer's power supply is probably dead.
Oct 17, 2012 | Bose Acoustimass 5 III System
Does the battery have to work for the lap top to work when pluged in on the Presario R3000?
Check your AC adapter if still work. Battery don't have to work when is on AC.
Dec 26, 2011 | Compaq Computers & Internet
The tapping went out on my stove. Working one day, stopped tapping the next. I have to light match to use
You might check that the outlet it is pluged into is working, if so lift the cover and check that the wires are all connected properly. Unplug before touching any wires. if anything is loose or disconnected reattach and snug it up.
Jul 09, 2010 | Maytag Kitchen Ranges
Servis washing machine trips fuseboard when start button pressed
Try pluging it on another outlet. If that don't work. Try using a stronger fuse for ur outlet
Oct 26, 2009 | Washing Machines
The dryer just quit working. The last item dried in their was a pair of tennis shoes. Next day it won't even turn on. Checked the thermal fuse and jumped it but it still would not start, spin, etc. Help!
This may not be a solution but try testing the outlet its pluged into or the circuit breaker at the main box. Stranger things have happened.
Oct 03, 2009 | Dryers
My machine is not starting
well is it digital or dial is the outlet its pluged into getting power if its a gfc outlet it might have triped try pluging in a lamp or somthing of that nature into the outlet, if it works check if any of the cycles work, depending on the age of the machine is where you would start looking for the next solution
Oct 03, 2009 | Washing Machines
Lookin for a charger for a craftman cordless drill
any sears or sears repair outlet
Jul 28, 2009 | Drills
Wii got pluged to a 220 volt outlet
I'm going to go ahead and say it probably fried the Wii. I would maybe try getting a new adapter either way if it's at reasonable cost and see if it works again though.
Jul 19, 2009 | Nintendo Wii Console
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
