Question about Asko Dishwashers
My Asko D3351 fills with water, heats it then pumps it to drain. No water is sprayed on the dishes.
  • 7 Answers
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Posted on Nov 02, 2007
SOURCE: Bosch SHU43C02UC/47
How to loose up the circulation pump
Posted on Nov 03, 2007
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
  • 677 Answers
SOURCE: Whirlpool Gold Dishwasher "Quiet Partner' Fills But Won't Wash
www.dishwasherfilter.com will fix your problem. its your water and not the dishwasher.
Posted on Jul 17, 2009
  • 351 Answers
SOURCE: f7 code
yes remove filter and water from under filter theres a small chamber at the back of the sump,it may be full of fat clean it with your finger then try running some heavy wash cycles to clean it.
Posted on Jun 17, 2010
Dishwasher is not washing the dishes. Motor sound like it comes on, Water is drained aout and put in but it appears no rinsing or washing goes on. Don"t hear the arms rotating either. It goes thru the...
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1776 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, as you mentioned. What you may not know, is the impeller itself is not serviceable, the entire motor/pump must be replaced unfortunately.
Before declaring it is indeed a motor/impeller issue, you said you hear a quiet sound of a motor starting once the unit has completed filling with water right ? Be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues. (try placing both spray arms at 12 o'clock position and placing a cup upright in the top rack. If the arms move and the cup fills, you've got circulation...if neither, you don't)
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump or severed somewhere between the motor and control, maybe where the door pivots during opening...but not likely.
This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders ( which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet. Check those other possibilities first and tell me what you find.
I'll watch for your reply.
Regards,
Macmarkus :)
Apr 19, 2011 | Asko D1776 Built-in Dishwasher
Dishes are not coming clean. I've tried reducing the size of the load, using all hot temps on every setting, etc.
Hi<br /> <br /> <br /> <font size="3" face="Calibri">If you are observing that the dishes are not clean, then you
Aug 21, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher is not cleaning dishes. Food is left on the dishes at the end of the cycle. Also, when dishwasher is emptying it's water, it gets very loud.
Hi
If you are observing that the dishes are not clean, then you’ll need to follow certain steps to be sure where exactly the issue. First thing to check for is the detergent cup and spray arms. Check if the dishwasher’s spray arms are working fine and all the holes of the arms are clear. Now try using a different detergent like gel or liquid based detergent to see if it helps.
Dishes are left unclean when the dishwasher is not filling in properly or when the water pressure is low. Check for water pressure and water inlet valve. The water inlet valve if faulty will draw very little or no water. However, if you observe that water pressure is fine and there is no issue with the Fill valve then check whether the dishwasher is draining. If it’s not draining then see if the drain hose is plugged or clogged. If drain hose is fine and the dishwasher is still not draining then there is some issue with the drain pump or drain filter. To check this you’ll need to disassemble the dishwasher and trace back the drain hose to a pump, remove the drain hose from pump and clean the debris from the pump and filter. Make sure you have lots of towels as there would be a lot of water coming out from the pump.
Next thing to check if the dishwasher is draining and filling properly is water temperature. Water temperature should be between 120 and 140 F. If water is not hot enough then heating element has gone bad, to check the element you’ll need a multimeter. Use the multimeter and check if the Rx1 reading on the meter shows reading between 1200 (1.2K) ohms and 1500 (1.5K) ohms, if not the heating element has died. Please post back if more information is required.
Daniel
Aug 08, 2010 | Maytag MDB7100AWB Dishwasher
F7 code
May 02, 2010 | Asko 24 in. D3350 Dishwasher
Whirlpool dishwasher has food particles baked on.
Heating element may fail. This will lead to the machine stopping part way through its cycle
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Dishwashers
Does not cleans dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
Dishwasher- dishes not clean
Hi
Thanks
Rylee
Dec 08, 2009 | Thermador DWHD64 Dishwasher
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Asko1585 sprayer arm not working
Most likely the circulation pump. On this pump there is mounted a condensator. This will help the pump to get started. If this is broken, it wont circulate the water up to the sprayers.
Jul 15, 2009 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
27 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
