Question about Toys
Gator air cooled gas quit firing - Toys
2004 John Deere Gator CS
Hi, although i dont know what a gator cs is i would suggest you first check that your valves are opening to actually let your fuel mixture into the engine. If the valves are opening / closing at the correct time you need to check compression on all cylinders. you may have sticky rings or worse.
Sep 17, 2017 | Motorcycles
That sounds to me like you need to replace the coils. They get intermittent with age. Work some then quit take a long time to cool down and work a little more when going bad.
Jul 20, 2012 | Maytag Dryers
GT90CH fires but no nail after twenty shots.
a bit of air tool oil might help, make sure you are not getting condensation in the line, otherwise you may have to dissassemble to clean
Jul 27, 2010 | Senco GT90 Clipped Head Gas Framing Nailer
Air conditioner quit working
If after switch on of the a/c there is no difference in the engine rpm with the solenoid latching up the a/c compressor with the fan working , then you must look for the fuse of the a/c which can be found near the main box inside the bonnet. replace and test. However if the ac works but there is no cooling then you must check for the gas pressure in the visual eye at the gas inlet. If you notice that there is heating in the cooling pipes then your compressor needs to be checked, gas leak in system, gas filling. Hope you check this out. Good day
Jul 21, 2010 | 1994 Dodge Colt
John deere gator 1999 4x6 overheating.replaced waterpump and thermostat
bleed air out of cooling system contact dealer for instructoins
Mar 17, 2010 | Peg Perego John Deere Gator HPX
My dryer will only stay warm for a brief time and then simply runs with cool air.
Those gas operating coils will get hot and quit and cool down and work some more. Intermittant little suckers. Some Repair Pix
Bonus stuff:
More Gas Dryer Enlightenment
Aug 31, 2009 | Frigidaire FGQ332ES Gas Dryer
Motor stops after heated up
Try and blow out the air finns with a air hose. and just blow all around it so it can get air to threw the air finns. do it while its cool and you can use a garden hose. Don't go crazy and hit the fuel tank air filter no more than you have to. I use air first than hose, Then air once more. let it set about two hours and fire it up.
I hope this will be of some help.
Aug 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Air conditioner quit cooling,
I have a 2007 Kia Sorento EX. I had a similar problem. I checked for leakage in the nozzle. The nozzle was repaired and I refilled gas. This resolved the cooling problem.
Jun 11, 2009 | 2003 Kia Sorento
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
