Question about AEG Washing Machines
Our AEG ?KO-LAVAMAT 88830 Update will not power up. Got back from holiday, loaded it up closed the door, turned the dial.It said "click" and the display didn't light up as per usual. Thoughts ?
beltronic205
  • 1474 Answers
SOURCE: AEG Lavamat 6250 - opening door?
Try spoon handle gently prise open
Posted on Nov 12, 2009
  • 174 Answers
SOURCE: AEG Lavamat 88830 Update
C7 error is th\at no heating of the water has happened. check the heater (most likeley) also can be faulty relay on electronic. ntc fault, pressure switch or wiring to any of them.
Posted on Nov 09, 2010
derrickbohan
  • 90 Answers
SOURCE: My AEG Öko Lavamat 86800
unplug it for a while and then plug it back and see what happens.
Posted on Dec 17, 2010
SOURCE: I have a new AEG
I have exactly the same problem - but with the additional concern that there was water in the outlet hose & the drum was damp. Who did you purchase yours from? What was the outcome? My machine arrived yesterday evening (Friday) & there's no customer service over the weekend.
Posted on Jan 08, 2011
some1cares_m
  • 5323 Answers
SOURCE: AEG Lavamat 88840 Front Load Washer that doesn't spin
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiNBy the way my advice is free cuz God is good!
Posted on May 22, 2015
Hi my AEG OKO-LAVAMAT 88830 is about 10n years old. Today I was cleaning my machine. I filled the machine up with water on the rinse cycle then turned it to pump. I did this a few times as I have had a...
According to my list for AEG Lavamat washers, 'C3' stands for 3 possible causes 1 'safety flood device operated' (I suspect it means that it has sensed some water in the bottom tray. Not an easy job to do but I would check for a leak underneath), 2 'pump fault' and 3 'module fault'. Sorry I can not be of more help ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 04, 2011 | AEG Lavamat 88840 Front Load Washer
Aeg lavamat error 40e
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board.
Feb 04, 2011 | AEG Lavamat 72640 Front Load Washer
Dec 17, 2010 | AEG L86800 Front Load Washer
AEG Lavamat 88830 Update Gives me the code C7. Whats wrong?
Nov 09, 2010 | AEG Lavamat 88840 Front Load Washer
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat washing macine C9 error code
C9 is a motor fault.
Normally it's worn out carbon brushes so you'll need to check them first.
If worn out or broken, replace them.
Then, you need to erase the code (reset the machine).
To do this, turn the dial to off.
Press and hold together, prewash and soaking buttons.
While holding them, turn the dial 1 click anti clockwise.
Release the buttons.
Turn the dial to off, to any program and back to off.
This should get rid of the C9 code.
It will come back if you don't repair the motor fault.
Dec 10, 2017 | AEG Lavamat 88840 Front Load Washer
I want circuit daigrame for aeg washing machine
I have an AEG öko Lavamat 64600 washing maschine and I need a circuit diagram. Can you help me?
Thanks,
Bridget
Dec 30, 2008 | AEG Lavamat 88840 Front Load Washer
AEG oko-lavamat 72630 update
It is a communication problem between the circuit boards inside the machine. It might be as simple as unplugging and replacing the wires, or you may indeed require a new circuit board.
Aug 05, 2008 | AEG Lavamat 72640 Front Load Washer
AEG Washing Machine: Door won't close
Hi again,
Any updates/development with your project?
Jun 21, 2008 | AEG Lavamat 74640 Front Load Washer
Washing Machines Logo
112 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
