I need drag washers, & a service for whatever may need repair.
I have a error code on my washer 1LC1 and the bottom LC1
call your local repair service for whatever the make is .
Jun 04, 2018 | Washing Machines
How do i repair a fishing reel model r2f cf-702/mhc
R2F Fishing Reel Parts‎
www.when.com/R2F+Fishing+Reel+Parts‎
Explore R2F Fishing Reel Parts
Discover More on When.com!
Sep 18, 2015 | Fishing
Need to know how to install the electronic control located on top of the motor. I know it goes there but not sure how it mounts on the motor. I have a Kenmore elite oasis washer, model number...
Welcome to FixYa.
I'm pretty sure I know what you're referring to and in fact I can explain what needs to be done to gain access and repair it...it's pretty easy once you see how.
First I'll confirm it is the RPS sensor you're referring...I think it has to be since there is no other "control" located down there.
It will look like this...
We can go about this two ways, I can guide you step by step on "how to" both access this and repair it, or I can send you a complete service manual for your washer, it's up to you. Whatever you think will best serve you.
You will need to provide an email address I can attach the "pdf" service manual to if you decide you indeed want it. I'll watch for your post and we can go from there.
Thank's for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Apr 06, 2011 | Kenmore Oasis HE 27082 Top Load Washer
The spin cycle sometimes it works sometimes it does't
Could be a clutch issue could be severe Outer Tub bearing drag.
If you want to DIY
Google this Neptune TL Washer FAV6800AWW
If you need help open a post in that repair forum and I will try help you through your issue.
Feb 15, 2011 | Maytag Neptune FAV6800AW Top Load Washer
The drum on my front loader is dragging and wearing against the plastic which is shreading off
Sounds like one of the support arms holding the inner drum has failed. It is very expensive to repair, most of the time a new washer would be the cheaper than the repair. Sorry
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water inside the drum.
If the washer is continuing to fill with water while not in use, this is often caused by a water inlet valve that is leaking by, or a pressure switch malfunction. The following link explains how to troubleshoot and repair:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
This is a very simple and inexpensive repair. If parts are required, you can order on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Use whatever parts source you like, but these sites offer great service with competitive pricing, so shop and compare. The first three sites on the list also offer helpful exploded view parts illustrations to help you locate and properly identify the parts you need. If you have questions, please let me know. I hope this helps you.
Feb 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Drops items I am trying to drag
if you are using a mouse with ball.... clean it, or better yet get a laser mouse. hopes this help.
Aug 30, 2009 | Logitech Marble Mouse Trackball
Kenmore he2 plus front loader washing machine comes up with an error code or rL
The rL error code during the clean cycle is likely caused by friction on the spin basket shaft since you indicate that you hear squeaking when the washer is spinning. The squeaking is normally caused by a bad bearing in the rear tub shell. I recommend that you have the washer diagnosed and repaired by a Sears service technician. This type of problem will normally require an extensive tear down of the washer to repair. It is not a problem that you can normally repair yourself.
Open the door & slowly rotate the spin basket to see if you can feel any kind of drag on the bearings. If the bearings check good, the control board is sensing a load & will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 10, 2009 | Kenmore Washing Machines
Sebo Automatic X1 vacuum 'check brush' light on
I work in a Sebo agency, where we sell and repair Sebos - although they're so reliable we don't get that many to repair.  What's "automatic" about this machine is that it automatically adjusts the brush height so that it's ideal for whatever floor it's on.  It does that by sensing the amount of drag on the brush.  On a wood floor, there's much less drag than on a carpet, so the machine lowers the brush as far as possible to get the optimum drag.  After a while (4 1/2 years in your case) the brush has worn so far that the machine can no longer get it down low enough to brush the floor effectively. That's why the light comes on.  There's still plenty of bristle to do a good job on carpet but, if you want to do the best job on your wood floors too, you need a new brush roller.  Change the brush roller, and you'll probably feel the suction's improved too!
Any questions, just post a comment and I'll help if I can.  I value your feedback so please remember to rate this response.
May 04, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
