Question about Kitchen Appliances - Others
I have a Staples SPL-TXC15A shredder that doesn't start when paper is inserted. The power light is on and it runs in reverse but won't start when paper is inserted.
I have cleaned the optical sensors on the input. I have done that before when it didn't shut off. I also cleaned the bin full sensors with no luck.
  • Kitchen Appl... Master
  • 18,342 Answers
You need to change the direction or travel switch. Auto will only work when the direction of travel is into the bin, but you probably know that. There is an interlock on it. Use a vacuum cleaner crevice tool and then the brush attachment on both sides of the head. If that doesn't work, my guess is that the forward reverse switch is faulty. You would need to strip it apart and check with a meter.
Posted on Jan 03, 2017
I have a staples spl-xc200d paper shredder. It runs on auto is that normal
If I understand the question then yes it should run on auto when the paper is inserted to be shredded. I have this shredder as well and mine is always set to auto.
Apr 19, 2017 | Staples Office Equipment & Supplies
I have a Staples Shredder model SPL-TXC6A (serial 0809026807), which I have been using a lot lately. The auto and reverse buttons will not function, & neither will the forward button.
If you have used it a lot, it may have tripped the thermal fuse. Normally, these reset themselves. One thing to make sure of,, is that the safety switch under the machine is firmly on the pin in the basket under it.
This is a light duty shredder, you can only use it for two minutes!
6-sheet, light-duty, up to 25 uses/day
Runs 2 min on / 4 min off
Nov 21, 2016 | Office Equipment & Supplies
Spl-1506x shredder only runs in reverse
Unplug the shredder... Take the top off and turn it upside down. Use a screwdriver to take the lower cowling off and look at the motor. If the mounting area where the motor sits looks melted at all, the machine is toast. If the motor mounting area looks good, look at the slot where the paper is inserted... there should be a sensor (that "sees" the paper when you insert it) at the paper slot. Check to see that the sensor isn't damaged.
Nov 11, 2012 | Staples SPL1506X (CrossCut) Shredder
Staples SPL -TXC15A Shredder on all the time
This is what worked for me.
1) unplug the shredder
2) put the selector in "auto" position. This pulls back the guard which blocks the paper and hids the sensor.
3) a little right of the center of the paper slot is the sensor. You can feel this by inserting a cotton swab in ths slot.
4) put some alcohol on the cotton swab and clean the sensor!!!!
Also the "bin full" sensors are under the shretter head. You can easily see those when you remove the head from the bin by flipping it over. I would advise cleaning those while you are at it. Mine were covered with dirt and dust.
Hope this helps!!
Sep 06, 2012 | Office Equipment & Supplies
Staple Model SPL-XC200D Paper Shredder, During the
Fixya does not sell parts and cannot identify sources.
Jul 18, 2017 | Staples SPLXC200D Shredder
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
May 09, 2010 | Staples SPL1050LBRX (CrossCut) Shredder
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
Kitchen Appliances - Others Logo
82 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
