Question about Singer Sewing Machines
I need to remove the bobbin basket on my Singer 211G156 my thread is caught below. I removed the two small screws on the half round plate but there is no give on bobbin basket.
  • Singer Master
  • 11,160 Answers
If you are talking about the bobbin case and it looks like the one below, it has a flipper latch at the very front that you just hook a fingernail on and open. Shouldn't have to remove any screws. The latch is the long vertical piece with the hole in the very center.
Singer Bobbin Case
Posted on Jan 04, 2017
  • 106 Answers
SOURCE: Looking for a lifter rock lever plate pad for a singer 211g156
Bit confused here, what is the 'make' of the machine and what do you mean by 'pad'
Posted on Mar 28, 2008
SOURCE: Bobbin thread getting caught
Check your Instruction manual - if you have taken the bobbin case apart to clean it, the shuttle must be reinserted with the little tab pressing against the piece you mention. It is under page 45 - "Caring for your machine" in my book. I missed it the first time I cleaned and oild mine.
Posted on Apr 05, 2008
  • 68 Answers
SOURCE: I have a Singer Confidence 7469. It has only been
The bobbin case is not supposed to move. It should only have a little bit of wiggle room so there is enough clearence for the thread.
Posted on Feb 25, 2010
SOURCE: singer bobbin thread not being caught
try rethreading the machine top & bobbin
change the needle--flat side to the back of the machine, make sure the needle is the right one for the fabric being sewed
clean under the needle plate & in the bobbin area for lint or theads
Posted on May 11, 2012
  • 1564 Answers
SOURCE: Singer 221--threads caught under bobbin cup, can't remove
Get out your magnifying glass and tweezers. Start pulling the threads
Here's a user manual that may help a bit.
http://www.singer-featherweight.com/sitetwopages/singfea.pdf
Here's a direct link to the service manual and adjuster manual ( the links will automatically start the download)
http://thefeatherweight221factory.com/page36.php
http://thefeatherweight221factory.com/page34.php
Have fun getting your 221 to sew. :)
Posted on Sep 19, 2012
SINGER TOUCHTRONIC 2001 How do I remove the bobbin case to try to clean out any threads or fuzz? See previous question regarding ratty loopy knotted bobbin threads on the underside of my seams.
Actually, the touch 'n sew machines, don't HAVE a bobbin case. What you see when you remove the bobbin is the bobbin basket. On other machines, the case goes in the basket, but on those there is none.
However, generally you can remove the bottom of the case relatively easily without having to remove anything else, and it will allow you to see and remove any debris that has fallen below the basket.
What you're experiencing may be because you didn't raise the presser foot when you are threading. That is the only time the upper tension disks that apply tension to the thread are spread, so that you can thread in between them. If you don't do that, either the thread isn't getting any tension at all when you're sewing, or the thread is only in the outer part of the disk, so not enough tension is being applied.
Although I have known that for many years, occasionally I forget myself--it's easy to forget.
Jan 13, 2015 | Singer Sewing Machines
Bobbin tread bunches and jams machine
If the bobbin is inserted with the thread spinning the wrong direction this will cause "birdnesting" - thread build up under needle plate, you need to cut thread to get the item off machine. flip the bobbin over into the case and try again. Also make sure you remove ALL thread caught up in "Birdsnest" when they happen.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 27, 2014 | Singer 2263 Mechanical Sewing Machine
How to replace bobbin assembly correctly on my singer merritt 4530 ? the threads been getting caught all around the bobbin assembly.
Yes, it should, and you might want to download your user's manual free at the Singer website, because replacing the bobbin case is pictured there.on page 41, along with instructions.
However, I can tell you that the feed dog plate with the two screws in is DESIGNED to be removed, and must be removed to get the bobbin case back in. It's important that you follow the instructions; the case must be inserted correctly so that it does NOT move, and make sure that it sits evenly in the bobbin basket (the thing that holds the bobbin case. While you are at it, you might want to also clean the basket, using q-tips with a drop of ONLY sewing machine oil on the cotton, making sure you also get under the lip before you put the bobbin case back in.
Jun 11, 2014 | Singer Sewing Machines
Machine is Jammed
Try turning the wheel to the right end manually----briskly back and forth to loosen thread that are caught in the bobbin. Remove bobbin and clear threads. If none, remove plate below needle to see if thread or fluffy threads are clogged below. No good...have it serviced by a professional.
Apr 06, 2014 | Singer 7422
Remove bobbin case from singer 5532
I used it once and then the thread jammed ,I had to remover the screws from the top plate and remove the bobbin case and untangle the thread. Now I can't get the needle to pick up the bobbin thread
any idea what I did wrong. I got it for Christmas and am very frustrated with it. Thanks
May 15, 2013 | Sewing Machines
Sep 08, 2012 | Singer Sewing Machines
Singer sewing machine bobbin thread knots rather than forming stitches or forms large loose stiches on bottom of fabric
What you have going on is a bobbin problem. The knots are referred to as birds' nests and happen when your bobbin thread gets caught on a piece of the bobbin casing. The large, loose stitches are normally caused by a problem with the bobbin case, a bobbin that is would properly, or when you're getting to the end of the bobbin's thread and the thread is loosely would on the bobbin at that point.
You're best bet is probably to buy a new bobbin casing. They're usually about $25 or so and you should be able to find one on eBay by searching for Singer (your machine name and model) under the Crafts category. The silver plate on top of the area covering where you place your bobbin into has screws you need to carefully remove (careful not to loose them!). If you need to, take pictures with your cellphone or digital camera as you remove the old bobbin casing so you can see how to put the new one in.
This should take care of the problem. If, for some reason it doesn't, you may well have a problem ALSO with your bobbin tension, and that should be looked at by a Singer Technician. You can find one in the yellow pages near you or probably by searching Yahoo Local. Happy Sewing.
Dec 08, 2010 | Singer CE-100 Futura Computerized Sewing...
How do I load the bobbin on a touch and sew model 775
To thread the bobbin, open the slide plate, make sure the machine is threaded all the way up as normal, take the thread and wind it round a few times round the presser foot screw, push the little lever over near the bobbin to raise the winder, slowly press on the foot control and it will wind the bobbin, when you have enough thread, close the slide plate and draw the thread to the back of the machine and start sewing.
Oct 13, 2009 | Singer Sewing Machines
I have a Singer Touch and sew 600E and need to know how to thread the bobbin?
thread the machine up as normal, presser foot up,open the slide plate, push the button over to raise the winder, take the thread from the needle and wind it round a few times round the screw on the presser foot, press gently on the foot control and wind the bobbin, when you have enough thread close the slide plate and draw the threads to the back of the machine and away you go.
Jun 06, 2009 | Singer 3116 Simple
Black bobbin case
If this is the machine I think it is the bobbin case is completely round as opposed to half round. If it is half round ignore the following.
Remove the presser foot and then the two screws which hold the needle plate. Lift off the needle plate and then lift out the old bobbin case. Clean all the lint out and then insert the bobbin case so that the less round part of it is to the back and the lip around the bobbin case is resting on the lip around the hook. Turn the hand wheel a few times to be sure it is working smoothly and not binding. Replace the Needle plate , bobbin and presser foot. Insert a new needle,thread the machine, Check your tension to be sure it is working correctly, turn the hand wheel again to be sure it is picking up the thread without binding and sew.
sewman7
Jul 07, 2008 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
