Question about Refrigerators
..why my elextrolux refrigerator temperature display for my freezer is alarming and blinking? what should we do?
  • 159 Answers
SOURCE: Refrigerator malfunction
samsung units have duel cooling. that means there is a evaporator in the freezer and the fresh food section. it is possible that the temp sensor in the refrigerator section could be bad. and they have been known to have defrost problems there to. the samsung is a complicated unit and its hard to describe how to repair since there is a lot of electronics that control everything. the best thing I could say is to unplug the refrigerator for a few minuets. sometimes this will reset everything and start the unit back to the factory settings. if that does not work I would call for service. hope it helped you some
Posted on Aug 04, 2007
aasc
  • 1606 Answers
SOURCE: GE PSC23MGNA refrigerator. No display light for
Sounds like you have a bad main control board . The original pt # is WR55X10552 . The replacement board is WR55X10656 . Your original board , is on a recall list , and GE should come out and replace under an extended warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
Posted on Nov 01, 2009
rickead1
  • 1998 Answers
SOURCE: samsung refrigerator RS264absh Freezer not cooling
I would check three things in your freezer seeing how your getting ice the t-stat ,the heater,and the fan these are the first things you check with ice build in freezer your freezer is what actually produces the cold the air from the freezer travels through small vents into your refrigerator sounds like a definite defrost probelm in your freezer
Posted on Apr 29, 2010
dniro592006
  • 121 Answers
SOURCE: centrigrade to farenheit
Read the manual
Posted on Nov 01, 2010
  • 2509 Answers
SOURCE: Door open alarm sounds and door open indicator
The switch which detects whether the door is open may be malfunctioning or the control unit to which the switch is connected is faulty. If there is only one switch it may be the same switch which puts the light on as you open the door.Does the light come on when the door is open? If so the switch if there is only one, is probably ok but the control unit is faulty.Look around the edge of the door frame for switches and check they are not stuck or damaged. I hope I have been of help but please do not hesitate to ask if you have any further questions.
Posted on Feb 20, 2011
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Samsung refrigerator alarm beeping continuously
May 15, 2016 | Samsung Refrigerators
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 03, 2015 | Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Apr 10, 2015 | Refrigerators
My Westinghouse freezer has an alarm beep that goes off every now and then and the only way to stop it is to turn off the fridge completely. In the fridge section the temperature panel flashes the...
Often these have door alarms. If the door isn't completely sealed shut then it will alarm and cause the temperature/thermostat to blink to warn of "warm" temperature inside the fridge
Mar 04, 2015 | Westinghouse Refrigerators
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
WESTPOINT upright freezer...alarm light blinking
Sir,
I need to know how to adjust WESTPOINT UPRIGHT FREEZER WVR-300W temperature? There is alarm light blinking every time and the temperature is not changing from 4c!!!! Thats mean, the freezer
Sep 29, 2010 | Haier HSE12WNA Top Freezer Refrigerator
Freezer, Ice Maker and Water dispenser not working
it has to get down to the proper temperature after the reset the set point is -4 for the freezer and 38 for the refrigerator. the numbers shown o\n the digital display panel stands for the actual temperatures. When the compartmnet tempertures go down, so do the numbers on thge display panel, and finally they reach the set temperatures. Once the system is stabilized , the display tempoeratures are the set temperature.
Jan 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
