What power lead do I need for my HD TV 586204
Lcd picture distorts when light in room is turned on. TV is on a HD entenna
This problem is most likely not from the HD antenna but from a power problem. WHen you turn on the light your drawing power away from the rest of the circuit most likely leading to an insufficient amount of power to run the TV causing the distortion.
Mar 01, 2011 | Televison & Video
I connected my playstation 3 to another tv and it
If you attached your PS3 to an HDMI capable TV it asks you if you want to switch to HD Mode.
However, once you attach it back to a regular TV you get no picture.
Follow these steps to resolve:
1. Turn off the PS3 so it only shows a red light. You can flick the power switch in the back then back on again.
2. With your PS3 connected to the TV and the TV on, press and hold the power button.
3. Hold the power button until the screen "flickers" and then immediately release.
4. Wait a few seconds and the PS3 logo should appear.
Feb 10, 2010 | Sony Playstation 3 (PS3) Console
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
Aug 26, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Probem getting sky to work with a new TV
An HD TV connects in the same way as a standard TV.
Connect a scart lead from the TV scart of the Sky box to the TV.
When you switch on the Sky box it should automatically switch the TV to the correct external input.
May 19, 2008 | Televison & Video
Digital TV
right hdtv stands for high definitian tv witch basically means if you buy a hd dvd player or blueray then you can watch the films in really high quality alot better than normal dvd. The same if you had cable tv or sky you pay a fee for an hd converter then this lets you watch certain channels in high def. So it basically means that your telly is capable of using all the new hd equipment thats coming out like the playstation 3 can play high def dvd's as long as you buy the hd lead as you need this due to the fact that it sends more data to the telly their for giving alot better sound quality and alot better piture quality when watching hd dvd's.
At the moment their are only a few tv channels that are using hd at the moment but this will soon change.
So to watch hd dvd youll need an hd dvd player and to watch hd tv you need to contact your cable or sky people and ask them what you need to do to watch hd programmes. they will then upgrade your box and should send you an hd lead to plug into your telly from the sky or cable box.
Hope this is helpfull and easy to understand.
Hd is well worth having as the quality is amazing you wont believe it till you try it i was shocked as the detail and quality is mind blowing its like watching real life, it really is that good.
Let me know if you need further assistance ok
May 14, 2008 | Sylvania 6427TE 27" TV
Cleaning rear projection screen
I read in the manual for the Sony KDF 50E3000 that you should use warm soapy water on a clean cloth if you aren't able to remove it with a dry cloth. I find that the microfiber cloths work best.
Feb 11, 2008 | Televison & Video
Ps3
hold down your power button when you turn it on, for 5 seconds, it runs the screen settings menu and puts it in the best possible option for the leads fitted. hope this helps
Jan 22, 2008 | Sony Playstation 3 (PS3) Console
Xbox 360 Premium
You should have received the lead to plug into your TV you should also have a lead to plug into your PC monitor plus power lead and brick. The lead for the computer monitor would be the lead you need to play on an HDTV. Please rate if useful, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
My hd tv
to view anything in High definition you have to connect to your tv using either the DVI, Component or HDMI inputs. Your cam or anything you want to view HD videos from will need to have a lead to suit these inputs, the component lead will consist of an input from camera to five seperate coloured leads or an oblong DVI connector or HDMI which looks similair to a usb connector. You will need then on your tv to select the resolution of 720P or 1080I to view the HD picture.
Jul 14, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
