Question about Craftsman Saws
I broke the retainer pin inside BLADE CLAMP on Craftsman Reciprocating saw Model 315.171081. How tofix??
4 Suggested Answers
SRF518
  • 232 Answers
SOURCE: Where to get a replacement quick change blade
have you tried Sears?
Posted on Oct 20, 2009
  • 6468 Answers
SOURCE: blade broken off in quick change tiger saw chuck
use a pair of tweezer to pull it out or a magnit
Posted on Aug 22, 2012
How do I replace the tool-less blade clamp in a craftsman 8 amp reciprocating saw
Craftsman Reciprocating Saw replace the tool-less blade clamp
Jun 10, 2015 | Craftsman Saws
Blade clamp
i purchased a clarke reciprocating saw, and the first time i tightened the blade it broke, where can i get the parts to fix it
Mar 09, 2014 | Clarke Power Products Electronic...
How do i intall a blade on a DW303 Reciprocating saw?
To install blade into saw:
1. Loosen set screw.
2. Insert blade shank from the front between the reciprocating shaft and the blade clamp.
Locate hole in blade over pin on reciprocating shaft.
3. Tighten set screw. If the blade should break off and the shank does not come out of the clamp,
be sure the set screw is loose and eject the shank with a nail or pointed object.
May 05, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
Saw blade loosens no matter how much or often I
put a little bit off LOC-TITE on screw, worked for me
Apr 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
How do I replace the pin?
toolpartsdirect.com has schematics plus you can order the parts there also,, but in my opinion that pin might have been part of the screw and it simply broke off
Sep 26, 2009 | Saws
Boot on the saw.
You are probably wanting to repair/replace the blade holding assembly. The boot does come off with persistence. You will have to remove the foot piece first (two screws). Try using long thin screwdrivers as shoe horns and be persistent. I agree that it is a poor design. Why the new improved blade lock assembly I'll never know. The nib breaks off that fits into the hole in the blade and then there is nothing to hold the blade. If all else fails to get the boot off you can cut it and order another boot. Remarkably, the boot isn't that expense. Unless you feel you can make a replacement pin you'll have to order the entire blade lock assembly and it cost about $20. I had the reciprocating saw for a tear before I used it and the holder broke on it first outing! Being loyal to Craftsman in the past, I hate to admit that these days many of the power tools are cheaply made Chinese junk. My advice, don't spend much to repair, cut your losses and buy DeWalt, Skill, etc. Hope this helps.
Jul 06, 2009 | Craftsman 8.0 amp Reciprocating Saw
Reciprocating saw-snapped blade-cannot be removed
What I would try is to spray some WD40 on the pin first and then see if you can find a small screwdriver or punch and try pushing the pin in further to release the broken blade. It doesn't sound as though it is anything major, maybe a burr on the side of the pin or possibly rust or debris. DON"T hit the pin because you might damage it or push it in and never get it back out. Looked at a diagram and it appears that they used roll pins to hold the clamp in place so it might be that one is cracked or mushroomed and you might have to drive them out. I suggest that you go to Searspartsdirect.com and type in your model number to look at the same diagram.
May 26, 2009 | Craftsman 8.0 amp Reciprocating Saw
Saws Logo
113 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
