Question about Rowenta Irons
I need the replacement power cord for DX1700 or similar
I took bottom off and took off plate that is over cord and then the power wasn't goig on and off, but the cord gets warm just at the base of the plug. So I think I need to replace only the cord. the DX1700 is discontinued but the cord looks like may rowenta model cords.
  • 43 Answers
SOURCE: Rowenta model dm 860 loose power cord
Most high end appliances (like Rowenta Irons) are made so repairs like that can be done. I haven't played with that model, but I did replace a cord on my Norelco. The torx screwdrivers you are looking for can be purchased, and are often found at either specialty electronic stores (not the average Radio Shack), automotive stores and quite readily online. They are also known as Torx Security bits or Torx Safety bits. Most appliances are made with those screws to prevent the average person from having a go at trying to fix it, but, if you feel comfortable enough with the electronics (even just to look for a loose connection), the bits are available and usually at a fairly decent price.
Posted on Jul 22, 2009
omaromid
  • 332 Answers
SOURCE: I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Posted on Feb 07, 2010
SOURCE: Power cord sparked and burnt. What tool do you
They are called TORX screws. You need a torx set of drivers.
Posted on Feb 12, 2010
Sheikhtijani
  • 1284 Answers
SOURCE: I need to replace the power supply cord on my Rowenta DX8600 iron
Hi, you need not to disturb yourself too much, just take the iron to any electronic repairer or electrician around you and they will replace the cord for you. They have the screw drivers for all types of screws...
Take care
Posted on Mar 24, 2010
heatman101
  • 43501 Answers
SOURCE: My Rowenta iron is leaking down by the cord. can
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
Is there any cleaning solution to use on the iron plate to clean it?
Yes there is a paste you use on a hot/warm iron and it cleans the sole plate well. Wal Mart has some in the laundry section where they have the spray starch. It's a little 3" tube on a card.
Jun 05, 2014 | Rowenta Effective DX1700 Iron with Auto...
IRon heats standing but the light goes out when I set it horizontal to iron a garment. I think the cord is needing replacement but need advice.
If the iron is not moved while it is plugged
in, an internal safety switch will turn it off.
- It will turn off in 8 minutes if left vertically or
in 30 seconds if left on its soleplate or tipped
over. A red flashing light indicates that the
auto-off has been activated.
The above information is from the Rowenta DX1700 Owner's Manual. I think most, if not all Rowenta irons have the "auto off" safety feature. If your iron is going off before the 30 seconds idle time, the sensor may be defective. If you are letting it sit on the sole plate longer than 30 seconds, you may just need to work faster. ;-)
Jun 11, 2011 | Rowenta Irons
We have a Rowenta iron effective model DX1700, less than a year old. It will not heat. Is there an iron made that will give satisfactory service for more than a year? Are they repairable?
If the cord and plug are ok (the wires in the cord often break just at the cord protector at the iron) the most likely other problems will be the thermal fuse(s) or the element. Thermal fuses can be replaced but if the element is gone that is unfortunately that. Take the back cover off and check for continuity from the plug to the inside connections using a test light or multimeter (the iron is of course unplugged).
Jan 19, 2011 | Rowenta Irons
My Steam Iron Rowenta dx1700 leaks on my clothes and turns itself off while I am ironong. I am ready to chuck it.
My brand new DX1700 iron leaks. Why is it leaking. I had a Rowenta Professional for 17 years and it never leaked. What do I need to do.
Jan 12, 2011 | Rowenta Perfect Iron
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
Rowenta Iron-Professional Luxe The power cord seems to short out when you move iron. You can wiggle it next to the movable ball and it clicks on and off. The two screw heads on bottom appear to be special...
I drilled out the nubs in the center of the screws. removed the screws, and took off the back plate. The problem is that the cord seems to be abraiding when it swivels, and eventually wears thru. It seems like a fire hazard and should be looked into by Rowena. Anyway, I cut out the damaged cord and reattached it. Problem fixed..
Oct 22, 2009 | Rowenta Irons
Shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Nov 18, 2008 | Euro-Pro Shark GI490 Iron
Not heating
The thermal cutoff device blew and must be replaced. It acts like a fuse when the iron gets too hot. Thay are very
cheap and it would be well worth replacing. Hope this was helpful.
George
Mar 24, 2008 | Rowenta Effective DX1700 Iron with Auto...
Irons Logo
80 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
