Question about Coleman Heating & Cooling
My Coleman furnace 4322/729 model lights the pilot but won't cut in . What could be problem ? Cleared lines Complete
    Master:
  • 946 Answers
Gas valve not opening? Does it have the exhaust blower that pulls vacuum switch allowing burner to light?
(1) Thermostat not working? Has to complete the circuit in or gas valve to open.
(2)Can be a stuck or bad gas valve. Try tapping the side of the gas valve body while thermostat is calling for heat. Tapping,not pounding. Like lightly,yannow? don-ohio (:^)
Posted on Jan 04, 2017
I have brand new coleman mobile home furnace model # DGAH056BBSB the pilot light (elec. Start) wont stay lit and it blows COLD AIR! PLZZZ HELP Ohio is COLD
here, the last sentence is important.
http://www.ehow.com/how_5615197_light-coleman-furnace.html
Further information here.
http://handymanwire.com/ubbthreads/ubbthreads.php/topics/28213/Pilot_light_won_t_stay_lit
But if the unit is new, it must be under some sort of warranty from Coleman and from the fitter.
coleman website, support, contact and warranty, but the website doesn't list, heaters, or furnaces? I am puzzled.
http://www.coleman.com/warranty/
Oct 23, 2015 | Coleman Heating & Cooling
Coleman evcon furnace
Did you clean the pilot orfice?? It has a very small opening about the size of a hair. You may have to use a needle to open the opening....Are you getting gas to the pilot orfice assembly from the Gas Valve when you set it to Pilot?? If not then check the pilot adjustment screw on top of the gas valve at the pilot tube. CW decreases flow.
Nov 17, 2013 | Heating & Cooling
I have a coleman model 7680B series 856 with a pilot light that won't stay lit
You need a themocouple, it's a cheap $10.00 part you can get at any hardware store, you have a standing pilot light furnace like mine, if your handy and safe you can put one in easy, youtube is loaded with videos on how to do it. These other answers are wrong for your unit.
Oct 26, 2011 | Coleman Heating & Cooling
Pilot light on furnace went out. how to i re-ignite?
I have experience with coleman furnaces installed in mobile homes. There is a red switch on the gas valve. Some models require you to slide the red switch to the top and hold. Holding is allowing gas to the pilot. You have to stick a long match,grill igniter, to stick through the inspection hole (a little flap or door to see inside the burner area) and hold the match over the pilot while holding the switch upwards at the same time. Others have a pilot selection on the gas valve which you slide the red switch to pilot and push down and hold while liting the pilot. You may need help with holding the door open while doing this. If you can you can use the copper line for the thermocouple to hold the door open for you. Good luck
Jan 15, 2011 | Coleman Heating & Cooling
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
My coleman floor furnace will not stay on
Have the thermocouple replaced, ensure the pilot flame is blue - not yellow, yellow indicates blockage in pilot
Oct 08, 2009 | Heating & Cooling
COLEMAN FURNACE BURNER NOT LIGHTING
There is a thermocouple "wire" that is supposed to be touching the pilot flame.
The thermocouple senses a flame (hot) and allows the heater to operate. If the thermocouple does not sense that the pilot is on, then it will not allow the furnace to operate.
Bend the thermocouple wire (or the pilot tube) so that the pilot flame is touchingg the thermocouple.
That shouls work now.
The air from the fan should not be blowing through the same cxavity that the pilot is in.
If it is, then you may have a leaking furnace whereby carbon monoxide may be seeping into your living quarters.
If the fix above works and the pilot stays on after the heater starts, then there is probably no leak.
Let us know the results ... post a comment or "RATE" this or another expert's solution.
Sep 16, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
104 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
