What power lead do I need for my HD 586204 - Computers & Internet
Just bought a ps3 secondhand but no scart lead do i need one?
You don't need a scart lead for your ps3 if you have a HD television. All ypu need is the HDMI cable (which is not included with a new PS3 but you can get very cheap from Ebay- don't bother with 'gold plated' or other 'high quality' cables as they are all the same output quality). The HDMI carries audio and video to your HD television, but you can use a scart lead for audio if and the HDMI for video if you want to use external speakers. The ps2 scart cable also works for the ps3 if you don't have a HD television. (note: a HD television is highly recommended because the quality is a hundred times better). Mine is a Samsung HD monitor which you can buy fairly cheaply.
Jul 28, 2011 | Video Game Consoles & Games
Fans run, but hd never spins up, power light never comes on. HD is tested good in another machine. External power supply is good in another machine. Have unseated RAM and hd cables and reseated. Any...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Feb 25, 2011 | Acer Computers & Internet
My psp works fine with the hd lead however when I try to use the leads provided there is no picture I have tried it on several TVs and still nothing, this restricts me to only using the hd lead?
hi there,
i'm assuming you mean the ps3 and not psp? all you need to do to reset the video output to analogue again is hold down the power button on the front of the console until it powers off again, this resets back to analogue output and your other leads that came with the console will work again. And the next time you use the HD lead again, it will show up on screen that an HDMI cable has been detected and do you want to use this? and you just select yes if you do. Hope this helps.
Jan 26, 2011 | Sony Video Game Consoles & Games
What pin # is this power switch,power led,power reset hd led,on intellistation m pro 6218, 3.2ghz
look for mother board morking,look for the pin that indecates (PS) is for the power switch (PL) power lead,(PR)(P res).and HD led
Dec 05, 2009 | eMachines T6420 PC Desktop
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
Aug 26, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Iomega Minimax HD, no power but lead light is on. Working fine, then I turned it on today & nothing, no fan, no light but the power lead green light comes on. How do I know if its the HD or the power lead...
In your situation I would :
open the minimax enclosure, and take the hd out, (just open the enclosure, not the hd itself), and then open your desktop and connect this hd as slave (I am guessing you have a desktop with IDE hd and that the minimax has an IDE hard drive in it.... or both your desktop and the minimax has SATA hard drives) and then when you turn on your computer you should be able to see your second hd as a partition and be able to see the info in there, yet if windows does not recognize it, that means your hd is useless., yet remember you have to change the pin on your external hd to be slave or auto detect, if you let it as master your computer won't boot, bout do not worry, after you unpluges the hd from your desktop everything will be normal
shutdown and unpluged the power cord from your desktop when adding/removing the hd.
Apr 18, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Cleaning rear projection screen
I read in the manual for the Sony KDF 50E3000 that you should use warm soapy water on a clean cloth if you aren't able to remove it with a dry cloth. I find that the microfiber cloths work best.
Feb 11, 2008 | Televison & Video
Xbox 360 Premium
You should have received the lead to plug into your TV you should also have a lead to plug into your PC monitor plus power lead and brick. The lead for the computer monitor would be the lead you need to play on an HDTV. Please rate if useful, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
My hd tv
to view anything in High definition you have to connect to your tv using either the DVI, Component or HDMI inputs. Your cam or anything you want to view HD videos from will need to have a lead to suit these inputs, the component lead will consist of an input from camera to five seperate coloured leads or an oblong DVI connector or HDMI which looks similair to a usb connector. You will need then on your tv to select the resolution of 720P or 1080I to view the HD picture.
Jul 14, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Open Questions:
Computers & Internet Logo
David Payne
David Payne
