Question about Generac Electrical Supplies
I need torque specs on oil pan bolts for generac gt990
2 Suggested Answers
SOURCE: I need toque specs for a Generac GT990.
Just happened to find a copy on-line for the Generac V-Twin GT990 Engine Service Manual.
E-Mail me : js2770@yahoo.com and I'll send you the PDF File for that. Good luck with your repair.
Posted on Sep 27, 2012
98 jeep wrangler tj 4.0 oil pan bolt pattern or layout. An torch specs
Bobby, oil pan bolt torques for 4.0 Wrangler. Oil Pan Bolts 1/4 84 in-lbs Oil Pan Bolts 5/16 132 in-lbs As far as sequence, see last link, start in center, criss cross pattern tighten snug all, then repeat to torque spec.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oil Pan Gasket leaking
http://jeephorizons.com/tech/99_40l_torque_specs.html
98 jeep 4 0 oil pan bolt torque sequence specs Google Search
May 21, 2016 | Jeep Cars & Trucks
Where can I find bolt torque specs
I suggest going to an auto parts store in your area and asking for the "HAYNES" manual for your make and model. It is an easier book to read than a "Chilton'. It will have all the torque specs you need. The book will probably cost 20 - 30 dollars. This is much less than it will cost if you torque something wrong. I would be careful trusting internet sources. It is a very worthwhile investment and a complete repair manual.
Feb 20, 2015 | Cars & Trucks
How to remove oil pan
jack it up, drain oil from drain plug on oil pan when drained remove and replace oil filter also. remove the pan bolts pull off pan and gasket.put new oil pan gasket on if needed.when oil pan bolts are back in, screw them in hand tight, then torque them down to specs and alter nate the tightening so it wont damage pan seal. any auto parts store can tell you the torque on the bolts for your car. good day!
Mar 31, 2014 | 1999 Chevrolet Venture
Need torque specs for 96 yukon 5.7 liter
Here's a link to the oil pan removal guide with pan bolt torque specs.
Jan 13, 2013 | 1996 GMC Yukon
I need to know he torque spects for the oil filter container the bolts on to the moter on a 94 BMW 318i...there are 6 bolts...I also need to know the torque spects on the alternator mounting bracket...
OIL PAN OR TRANSMISSION PAN BOLTS TORQUE ABOUT 7 FT LBS. CAN GET SPECS ON BOLTS SIZES. IF BOLTS SIZES IS 13M I4M 15 M TORQUE BOLTS ABOUT 55 TO 80 FT LBS
Nov 11, 2010 | 1994 BMW 3 Series
Need the torque specs and sequence for the engine oil pan 1999 potiac sunfire 2.4
Torque on the oil pan bolts is 18 lb/ft. Tighten in a criss cross pattern slowly tightening the bolts down making multiple passes until you have them torqued.
Jul 15, 2010 | 1999 Pontiac Sunfire
I need toque specs for a Generac GT990. Head bolts and rod bolts.
May 08, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
Need torque specs for oil pan bolts
torque specs for these bolts can be found in a Haynes or Chilton manual availiable from your local parts store, or maybe at your local library, however these bolts are usually no more than 14 ft pounds, unlike cylinder head bolts, the bolts do not need to have any stretch factor to hold the oil pan gasket in place or sealed.
May 17, 2009 | 1997 Ford Ranger SuperCab
Electrical Supplies Logo
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
