Question about Home
Toilet water leaking in shower - Home
  • 171 Answers
SOURCE: leak in the shower is leaking water through the ceiling
Hi lorenzotwalk,
I'm Harvey the Master Plumber.
Your problem is: When you use the shower, water leaks through the ceiling.
First, since it only leaks when you're using it you can ignore the water lines. Now comes the detective work. Look very closely at any place the water can squeeze thru, i.e. cracks in grout or caulk, etc. Don't forget to look on the floor imediately outside the shower and around the shower door if any. If found it must be scraped out, cleaned and dryed to get good adhesion, then caulked with a high quality silicone caulk (color of your choise). Any other caulk will crack no mater what they say.
Let dry for 24 hrs.
If you havent found this kind of problem it's time to look at the drain line connection. You may have to open the ceiling to do this, that's why I'm always carefull in the first step. Turn the water on and watch the drain connection. If it leaks there, it must be repaired. In this case you might cunsider checking the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 19, 2008
  • 119 Answers
SOURCE: i have a shower tray and a toilet fitted to a
need more info
Posted on Mar 29, 2010
SOURCE: my shower drain was running slow during a shower,
Yes water can back up in a drain and flood out lowest opening, which would be a toilet flange at floor level.
If tub is draining fine, then clog is probably near the toilet, but below floor flange level, and therefore not inside the tank ... judging from your description.
If you are in a house, go outside and see if there is a vent stack on the roof directly above toilet. If so, you can run a snake down from there.
You can also run a snake down through "s" shaped toilet trap and enter the pipe that way.
Another option is to remove the toilet and run snake directly down hole, and then reattach toilet.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 25, 2011
You can try using rock salt and boiling hot water down your drains. That will help if you have roots getting into your line. Chemicals are not very good for your pipes. If you have PVC drains the chemicals can eat a hole in the pipe because most of them have acid in them. They are also bad for your health (breathing in fumes, getting on skin, etc.) If the line is broken down, has a break in it, it will need to be repaired.
  • 7 Answers
SOURCE: sewage backs into the shower when the toilet is flushed
Since you are in a basement, your plumbing may run into an ejector pit, which is a heavy duty type of sump pump pit that can grind up toilet paper and shoot it up into a main drain pipe at a higher level. That may be why the upstairs doesn't affect your plumbing. Look around for a steel lid, about 20" diameter with two pipes coming out of it (usually 2 inches diameter). See if the circuit breaker is tripped. Sometimes, a light tap on the pipes near the lid can get the pump float to turn on if it gets stuck. Good luck.
Posted on Apr 08, 2013
Does shower / tub drain into black water tank
Would depend on the plumbing, but usually yes. Only toilet water doesn't.
If you have access to the black water tank, you can put dye in the shower, and then test it.
Jul 07, 2016 | Home
Help me locate a leak in the bathroom
need to check connections going to shower. turn on water and see if runs down lines. also try to reach up to the sink connections a do the same. they tend to come loose. should be able to hand tighten. also check behind toilet at connection.
Oct 08, 2014 | Jayco 2011 Greyhawk 31 SS
Sewage backs into the shower when the toilet is flushed
Obviously the drain line from your toilet to main drain out of the house ( used by upstairs ) has a blockage from your toilet line to "Y" in to main drain line. Depending on how it has been plumbed, there may be a clean-out between the 2 that can be used to remove the blockage. Your drain for shower is piped in to same line as toilet, thus when blocked at other end, overflows to shower. You can try some drain cleaner down shower drain if it will go. You might get lucky and release the blockage before plumber shows up .
Sep 16, 2012 | Home
My shower drain was running slow during a shower, and when i stepped out i realized that the toilet was leaking from the bottom -screw under cap on left side. i am at a loss and do not even know where to...
Jan 24, 2011 | Plumbing
Jan 24, 2011 | Kohler - Toilet - Two-piece - Highline -...
The shower stop draining, the toilet stopped flushing the water then started dripping thru the ceiling!! help. its stinky too!
HI is the shower and toilet on the second floor???
If so iets your 110 waste pyp that is blocked and u must try and look for an inspectoin eye to plunge it. dont throw draincleaner down your pyp becose you also have a leak. the drain cleaner can make the leak worse. if u dont get an inspection eye call a plumber. becose u will probebly need 1 to fix the 110 pyp where ever the leak may be.
Jul 18, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Shower gets hotter or colder when toilet is flushed.
This is typical for an installation without a balanced valve/anti-scald valve on the shower.
If you are using manual on/off valves on the shower, about the only way to fix this is to install the device mentioned in the previous paragraph.
May 03, 2009 | Rheem Tankless Hot Water Heater...
Saniplus motor (flushing noise) keeps repeating
I believe you have a problem with a leak. The pump is filling back up. See is the water is leaking out somewhere. Hopefully, you don't have a leak under the house. The water coming into the pump is going somewhere when it comes on.
Jan 28, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
SHOWER HOT WATER SCALDING
hi as you are probably aware ,when the toilet is flushed the water pressure to the shower is reduced so you get hot/scalding water unfortunatly there is NO easy solution you could put a needle valve in the supply to the toilet and with trial and error by turning the valve down reach a compromise between the time it takes to fill the flushing tank and the shower temp the only real solution is to feed the toilet and shower off independent supplies but in most houses this is impractical if not impossible silk090
Jan 08, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
85 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
