Question about Vacuums
No suction what can I do? I took it apart to clean and when I put it back together it still has no suction. What should I check for?
  • Vacuums Master
  • 1,417 Answers
Follow the suction path starting at the motor, follow how the air travels through your model from the motor to the carpet. It has to be somewhere in there you have a clog or a suction leak.
Posted on Jan 03, 2017
How do i put the lid back together on a moulinex serie f30 after taking it apart for cleaning
One shouldn't take things apart if one cannot re-assemble them :D
Take it to your local vac shop.
Oct 29, 2014 | Vacuums
Hoover nano cyclonic shut off while in use/no suction when turned back on
That is more than likely the problem, NEVER put wet or even damp filters back into your vac
Oct 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
Kirby Tradition vacuum has low suction
The emptor, the plastic assembly at the bottom of the bag may have a clog in it. Twist that assembly off and check it out.
Jul 09, 2017 | Vacuums
My electrolux ergorapido does not seem to have much suction, it is also very quiet. is this just the way it is?? i am the second owner, i have cleaned everything.
I took mine completely apart, removing every screw to get to the motor which was full of lint, hair and god knows what. I removed all the debris I could by hand, put it back together, and it works like new. I think debris gets in if the filter part is pushed too far down and the hole in the cup is open to the top part. My husband wanted to throw it out but I figured "what the heck". It's broken, it won't get more broken if I take it apart, it's only a year old.
May 09, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
Wiring schmatic for kenmore canistar vacuum
Generally, there are two wires inside the unit which connect to the wiring going down the suction hose.  Since the unit is a/ doesn't matter which of them goes to which terminal.  The wires are switched in some cases.  Look for the open terminal.
Dec 19, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Lost suction
Remove the sole plate turn the 3 plastic screws to unlock & lift off.
Now remove the blockages that have accumilated from the oppening of short clear hose.
Check you can turn brush roller & check belt.
Now reassemble switch on pull handle back & look under machine is brush spinning ?
If not check the knob on side of machine is in drive (D) position.
Dec 27, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
