Question about Bose Audio Players & Recorders
Bose remote works but won't turn on radio we have 2 and both remotes work with the same radio but won't turn on the other it has power but won't turn radio on or change the time why?
  • Randy Rodriguez
    Randy Rodriguez Jan 04, 2017
    I've tried all of these things except check the transistor how do I go about doing that? I've clean the lens on the remote the weird thing is that both remotes work with the bose radio in our room with no problem just not working with the bose radio in our living room that use to work I've plugged it in several outlets but it just powers on and the remote won't make any connection with the radio for some strange reason I've even used a blower to blow out any dust that was in there including changing the batteries that is why I know it's not the remote but I do appreciate everyone's help thank you
SOURCE: Daylight savings time - cannont change time
hold down either the + or the - depending on how you want to change the time. If you just hold the button down for 3 to 5 seconds the time will start to go up or down.
Posted on Nov 04, 2007
  • 14 Answers
SOURCE: Remote
The IR "bug" provided with the Bose 18/28/38/48 models is an IR emitter which sends out IR control codes to another component. The system is designed to have the Bose remote control be used to control the TV and the dish box. The Bose media center has a strong IR blaster in the front which will flood your room with the IR codes to control your TV or Dish box. The TV sensing device must be placed at a location on the TV where specific voltages can be detected. The location will vary depending on display type you have - plasma, LCD, tube or rear projection.
Posted on Dec 24, 2007
SOURCE: Bose 321 Remote not working
Pull off the front panel, be carefull there is a ribbon attached. Detach the ribbon. There are 2 ribbons attached to the front panel, one that leads to the IR (remote sensor) and other for the controls on the top of the unit.
Most likely the ribbon that goes to the IR sensor detached itself, this is common if the unit is dropped etc. Insert the ribbons (2) re-attach the front panel and the remote should work fine. You'll notice some tape on the IR ribbon, I suggest using some stronger tape, BOSE tape thats not very good.
This happened to me on my 3-2-1 GS II system and fixed it.
Posted on Jul 04, 2008
  • 5 Answers
SOURCE: changed batter remote start not working
Hello, What has happened is your remote has lost its programming.. Just like with most electronics, when something is reset or powered off, or even when the battery dies ....the programming software is lost. The remote has to be reprogramed either by a dealer (suggested) or by an aftermarket outsource..Hope this helps...This could help with almost all remotes.
Posted on Nov 22, 2008
  • 483 Answers
SOURCE: Bose Wave Radio - Need IR Codes for cable remote
Check this manual,
this will guide you through the setup again :
Posted on Mar 25, 2009
Why bose wave radio touch pad does not work ?
There's a setting to turn the touchpad on or off. Yours has probably been turned off. Here's how to turn it on.
1. Press and hold Alarm Setup (Menu) on your remote until -SETUP MENU- appears in the display.
2. Press Tune/MP3 until TOUCH PAD- is displayed (8 presses)
3. Press Time- or Time+ to select OFF or ON
4. Press Alarm Setup (Menu) to exit the menu, or simply wait 10 seconds.
You're done!
Jul 22, 2014 | Bose Wave Radio
I have a Bose Wave remote. Battery was replaced with the CR2032 and placed on plastic bracket and slide back into remote control. There appears to be no signal/power to Bose Wave unit. The battery is...
Remotes only allow you to avoid walking across the room to touch the unit for certain functions - like POWER. They don't actually enable or disable its ability to turn on if power is available. Walk over and touch the power control. If it turns on the remote is still malfunctioning.
Read this procedure to possibly fix the remote:
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Aug 04, 2011 | Bose Wave Radio
My remote will not cut on my Bose Cinemate system. I have changed the batteries in my remote and the red light on the receiver is illuminated, so I know the system is operational, . I've also unplugged...
It seems to be a common misconception that the remote is necessary to turn a device on. All devices have hard-wired power controls. Does THAT work? It is unclear which device (remote or the Cinemate) is malfunctioning. If the Cinemate won't turn on by its own power switch the remote won't magically bypass whatever the problem is.
The Cinemate Manual offers some steps to take if it won't turn on, as well as other guidance.
Jul 31, 2011 | Audio Players & Recorders
Remote does not work, battery is good. Can I program my dish network remote? If so what codes can I use.
Sorry to hear about your original remote; we would be happy to help you with addressing your DISH remote to your Bose Wave Radio. Here is a list of some of the codes that we havefor Bose Wave Radio: 761, 664, 656, and 639.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Bose Wave Radio provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Bose Wave Radio. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
Nov 21, 2010 | Bose Wave Radio II
I ordered and received a new remote for my Bose radio. Mine is the old type purchased in 1997. My problem is the new remote does not work, and yes it did come with a battery. Is there something you can...
The old and new remote look alike?Not than it have diffrent radio frequencies.The remote will not work,with the Bose radio you have.Call bose custumer service,ask the remote the match ur Bose radio make and model.Return the remote u have,get a replacement matches ur Bose radio model or look alike to ur old remote.
Sep 04, 2010 | Bose Televison & Video
The remote for my Bose Wave radio-CD no longer works. I have changed the battery and put a new battery into another Bose remote--no luck and I want to play my Christmas CDs! Help!
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug it back in
  • Make sure you’re pointing the remote directly at your Wave® music system. If the system is placed above table-top height, be sure to angle the remote upward while pointing
  • Check for possible sources of interference with the remote’s infrared (IR) signal, such as bright lights or solar glare off of a window. Make sure nothing is blocking the path of the signal from the remote to the Wave® music system display. The remote will not work properly if there is something directly in front of the display
  • Wipe off the small clear lens on the front end of the remote
  • The remote is designed to work within 20' of the system. Greater distance may cause intermittent response
Dec 05, 2009 | Bose Wave Radio
My bose wave radio II remote is not working. I
It will work without the remote, but can ve very unconfortable. If you have a webcam or digital camera or cell phone with camera, then point it to the small lamp in front of the remote and press any button. If the light blinks or keeps on, then the problem may be on the radio receptor. If light is dark, then take it to an electronics store an ask for an INFRARED LED DIODE replacement. This should work well.
Nov 20, 2009 | Bose 35503 Remote Control
Need v30 bose code for remote
Bose V 30 works on Radio frequency ............. so you need to have a unversal radio frequency remote conrol..... no IR (infrared) remote can control a bose lifestyle product..
why not use your bose radio frequency remote( the v 30 remote) to control the dvr plyer from motorola.. you can used the remote even to control your tv and other deices ..
all codes for your other systems are available in th e system settings option under remote control category to set up your system to control other devices
Feb 21, 2009 | Bose Lifestyle V30 Home Theater System -...
I changed the battery in my remote, and it works fine.
Oct 22, 2008 | Bose Wave Radio
Bose wave music system
Check remote and replace its batteries.
Does this remote work on any other device?
Sep 16, 2008 | Bose Wave Radio
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
