Why won't my Splendid Ariston washer spin during a regular wash cycle?
The washer stops, unlocks after it drains and all lights start blinking.
  • yadayada
    yadayada Jan 03, 2017
    Model number, front load?
  • J. B.
    J. B. Jan 03, 2017
    I found the filter. There was a plastic tooth pick in there. Must have been stopping the pump from spinning. It's spinning now. By the way. My machine is a front loader. The filter is on the front behind a kick plate. It was easy to get to and clean.
  • Washing Mach... Master
  • 17,543 Answers
Remove the kick plate from the front of the machine and you will find a removable screw-in bung. Put something underneath to catch water. When you remove it, you will find a plastic toothpick in there which is jamming the pump impeller. The safety feature stops the machine spinning if the pump is not working.
Splendid Ariston Google Search
Posted on Jan 03, 2017
Whirlpool WTW4950XW Washer won't go past the sensing cycle.
It may be as simple as a defective door switch or even a clogged drain hose (the hose between the tub and drain pump. Here are some videos that may help you more than i can. This guy knows:
http://www.youtube.com/watch?v=Aq7a3j7pFUM&playnext=1&list=PL5258B1D98A50745F
Jan 12, 2013 | Whirlpool WTW4950XW Washer
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
Jan 05, 2010 | Ariston Technologies Washing Machines
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
