Question about Filter Vacuums
Versa steam and vac steam will not work changed water filter now what?
5 Suggested Answers
  • 3614 Answers
SOURCE: lost instructions for hoover steam vac
kindly please wait...
Posted on Jul 13, 2008
  • 281 Answers
SOURCE: Hoover steam vac clean water reservoir leaking.
take the clean water tank out and look on the bottom for a fitting that screws on make sure its tight.also inside of that fitting trhere should be a washer or an oring to keep it from leaking.if thats not the problem then your pump mightbe leaking.for that i would take it to a vacuum repairman.i hope i have been of some help.please leave feedback
Posted on May 01, 2009
  • 11 Answers
SOURCE: Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Posted on Oct 22, 2009
  • 12 Answers
SOURCE: hoover steam vac, brushes won't
There are three things to check when experiencing 'no spin' on the cleaning brushes. 1) Check the small pull out filter screen under the machine. It must stay clean for air to pass to the turbine which powers the brushes. 2) Check that the long shaft on the brush assembly is not broken off. This shaft inserts into the turbine motor and powers the brushes. If you're handy you can replace just the long shaft brush rather than replacing the whole brush assembly. Look for the brush on Ebay 3) If you're handy you can dissemble the machine and inspect the turbine motor which powers the brushes. In all cases the bearings seize in the turbine. You can often free them up and re-lube them to get more service from them or simply replace the turbine assembly. Don't throw your Steam Vac out because the brushes no longer can fix it!
Posted on Oct 22, 2013
Hoover steam vac modal # F5915905
I can tell you this you need to replace the hoses and seals that run through the cleaner and are used to carry the water from one place to the next and replace the sprayers to
Mar 20, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
My shark vac and steam model mv 2010 pump wont come on help?
If your not using distilled water the machine is probably loaded with mineral deposits from hard water and is plugged. you can try running some vinegar through it which may or may not work depending how plugged it is.
Oct 22, 2013 | Shark Vac Then Steam Mop MV2010 NEW
My shark vac then steam will not steam anymore and I am doing everything right. How do I fix this problem?
im not familiar with that brand but i am an electrician and vac tech. i would if i were you i would check and make sure the heating element had power at its connection. if there is power replace the heating element. plenty of online vac parts stores have schematics along with a parts list to help you locate part in vacuum.
Feb 13, 2013 | Shark MV2010 Vac-Then-Steam 2-in-1 Vacuum...
Soap leaks thru handle
It sounds like a hose or water line has come loose.
Jul 05, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
Water is leaking from bottom of cleaner
you may just have a split pipe from the water tank and thats why its leaking water out
Jun 20, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My shark vac is getting hot but hardlthe steam is coming out to
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
Aug 25, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F5906-900 Steam Vac
Make sure that that the lid for the dirty water tank is locked on to the bucket, the other is make sure that the filter on the inside of the lid is not all the way up, needs to be a gap 1/4 inch or so.
Aug 19, 2007 | Hoover F5906-900 Upright Steam Vacuum
Vacuums Logo
23 people viewed this question
Top Filter Vacuums Experts
Shekar Avadhani
Are you a Filter Vacuum Expert? Answer questions, earn points and help others
