I have a Cashiers Check for 22546.32 and I want to make sure it is GOOD
On the bottom of the check the numbers fro left to right are : 02549385 041000124 4000020204 ...Check # 2549385 Dated 12/23/16 upper right corner 6-12/410 Check made out to me
harvester3
  • 181 Answers
SOURCE: Dell laptop pointer problem
This is a very common problem for most Dells this age.
You can try this repair if you feel comfortable.
Remove the keyboard by removing the power button bar (just gently pry up from the right side working left)
re-insert the mouse cable which is coming from the pad/palm rest. Re-assemble.
Check if all the screws on bottom of the unit are tight, especially around the palm rest area.
Good luck
Posted on Nov 06, 2007
SOURCE: Number 2 in upper right hand corner of screen
Had this problem also when I rebooted my Time Warner Cable box. Unplug everything from the wall including power strip and wait 60 seconds then plug back in and turn everything back on. Worked for me and havent had a problem since. Time Warner does not know what causes this yet.
Posted on Feb 01, 2009
heavymetal77
  • 721 Answers
SOURCE: My Dell inspiron LCD 1525 has broken. The power
You need a new lcd screen & while at it replace the inverter.
Posted on Jul 14, 2009
  • 2501 Answers
SOURCE: I have a WR165 Armitron watch and I cant change the time
You can get a of instructions from the Amitron site
"/www.armitron.com/watch_instructions.asp"
Scroll through the instructions until you find a watch that looks like yours and download the instructions.
Posted on Feb 02, 2010
  • 75 Answers
SOURCE: The projector is an NEC model VT590 and is
It is not the smartboard, lamp or the computer as well know, it's the projector itself. This may not work but you at least need to try press the auto adjust button on the projector and then adjust the clock/phase in the menu. If not you will need to send in to NEC it could by the color wheel. Usually they have a warranty for a couple of years.
Posted on Jun 05, 2010
I NEED TO FIND OUT IF A CASHIERS CHECK IS GOOD
Deposit it, wait two + weeks, then do not worry. Do not trust. For some strange reason (lazy) banks do not tell you if the check is fraudulent until it bounces.
May 31, 2017 | Computers & Internet
I want to replace a current dual outlet with a combo switch outlet where the switch controls the outlet.
Based on what you said, your hot wire feeds the top left and the neutral connects to the bottom left. The two brass on the right should be connected to each other with a brass tab. If you look at it, you should be able to see it.
This is the way it works: hot feeds top left, when switch is turned on, hot goes through to the top right which also feeds bottom right. Now the outlet is powered.
If you are not sure, use a multi meter set on continuity and check from the top left to the bottom left while turning on the switch. Good luck!
Jan 28, 2017 | Electrical Supplies
How to bleed radiator aprilia sx 125
u must seek a repair manual for ur model--or go to library sec629 and view the books--asian bikes are similar
Feb 27, 2014 | Aprilia Motorcycles
I bought a Polaris trail boss 250. I need the serial number. Could it be *1560086*
The serial number on most Polaris atvs are on the left side bottom frame behind the front wheel and will consist of 17 digits. Older Polaris atvs, however, did not have to use the 17 digit VIN because there wasn't a standard set in place. For these atvs check the right frame support by the shift lever. There should be a number stamped in place and will have asterisks before and after like the number you have posted. I can't be for sure if the number you have is correct, but it sounds pretty good. You can call a polaris dealer with the number and they can put it into the polaris website to check for sure.
Nov 06, 2011 | Polaris ATV
Clonking noise when turning the steering wheel back & fro or left to right
You have a bad cv joint. It could be either the left one, or the right one, the only way to know for sure is to look for a busted boot on the cv axle. The affected axle will need to be replaced.
Apr 15, 2011 | 2002 Toyota Camry
Loud groaning or scaping metal noise when turning wheel to right, and sometimes left. Had right upper ball joint done, made no difference.
if it's while driving, then it may be the wheel bearings.
to check, jack a front wheel, grab the top and bottom and rock the wheel to and fro, you shoild have a slight bit of free play but not so as to notice movement. any more than 2mm and the bearings either need greasing or replacing.
Feb 16, 2010 | 2001 Chrysler Sebring
Right turn signals stay on, left stay off.
Check the ground wires on both of the right turn signal lamps.
Be sure the lamp sockets aren't corroded. Be sure the pins at the bottom are clean and make good contact with the bulb bases.
Rapid flashing usually means a bulb is out.
Jan 16, 2009 | 2005 Honda VT 750 Shadow Aero
Settings for a new watch
http://www.adidas.com/campaigns/watches_fw07/content/index.asp?strCountry_adidascom=us&strBrand_adidascom=performance
check it here.. you will surely be able to solve it as i have just done...
press top left and it will say HOLD for setting.. so hold it... then choose one step after the other with the left bottom.. and increase with right top and decrease with right bottom.. rest you can find in the manual at the website... good luck...
Nov 27, 2007 | Adidas Digi III Watch
Water/ice led indicator malfunction
Daniel, first check the harness that comes out of the freezer door bottom. Make sure it that is is connected right and there are no wires broken or pinched. Then check the dispenser board connectors. On the back right there is a main mother board. On harness J4, top left, 5 pin harness, check for a steady 12V DC voltage on pins J4-1 and J4-2, numbers reads from left to right. If you have this voltage, replace the dispenser control board. If you don't replace the main mother board. Catriver..post back.
Sep 17, 2006 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
