Charger for 19.2 volt item 241- 9904 - Computers & Internet
  • Computers & ... Master
  • 18,320 Answers
Hello I need the 14 volt 1000ma barrel-end charger for the Kalee Fire Truck. 40029 I can't get it anywhere
One of these. Here you go
Kalee14v_BatteryChargerBarrel_1000mA Kalee 14v 1000mA Battery ... > RideOn and Toys > Replacement Parts Best price for Kalee14v_BatteryChargerBarrel_1000mA Kalee 14v 1000mA Battery Charger (Barrel End) Kalee 7.5v 1000mA Battery Charger (Barrel End): Toys ... Kalee 7.5v 1000mA Battery Charger (Barrel End): Toys & Games.
Kalee 14 Volt 1000ma Battery Charger (2-Prong) Kalee 12v 1000ma ... Kalee 14 Volt 1000ma Battery Charger (2-Prong) Kalee 12v 1000ma Charger (Labeled 14v Charger) ... Kalee 12v 1000ma Charger (Labeled 14v Charger). This item usually ships ... Mini Motos 12 Volt Barrel-End Charger $31.99. Kalee 6v ...
Oct 23, 2017 | Cars & Trucks
Need battery charger for jump start vec021stc
If your model jump starts 12v batteries, it likely will be the same as this generic replacement charger on Amazon.
I replaced mine and the open circuit (no load) voltage of the charger is from 18-19 volts. But it charged perfectly.
Mar 29, 2014 | JUMP START SYSTEM
Where do I find a 21.6 volt battery charger for a Kawasaki saw?
Mar 19, 2013 | Saws
Battery charge light flashing amber
Ok, lets start slowly, do you have both a new battery and a new battery charger? If both attempt to use your old battery with the new charger. Also could be a bad charger or a shorted out battery...
Good Luck
Feb 13, 2013 | HP Compaq nx9600 Notebook
Hi, i have svoa labtop and now my charger adapter got burnt due to electrict short. Now my charger is not working and i cannot use it.
OK. But I don't understand what the problem is.
AC adapter (Charger) is burnt out, by a new one.
Look at the old 'charger'.
Look at the label.
Input: 100 ~ 240VAC/50 ~60HZ.
100 to 240 Volts AC, at 50 to 60 Hertz. (Cycles per Second)
This is what you need to know.
What is the output voltage of the original charger?
Output: 19VDC @ 4.63A
19 Volts DC at 4.63 Amps. (Amperes)
Your charger MUST put out 19 Volts. (For the example)
It WILL be DC electricity, so don't worry about that. (Direct Current)
[Your 'charger' is more than that. More than a charger for the laptop battery.
It is also a Converter. It converts the 100 to 240 Volts of Alternating Current, (AC), into a low DC Voltage.
Plus it charges the Battery, WHEN needed ]
Post back in a Comment as to what the exact query is.
Jan 25, 2013 | Computers & Internet
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
Need a battery charger for the 21.6 volt battery
It will work if it is of the same charger/receiver style. The only issue is that you will only be charging to 19 volts and not 21.6, I would estimate by doing some simple math that you would lose about 6-8% of the batteries capacity but you would be able to use it.
Jun 05, 2012 | kawasaki 21.6 volt Cordless Drill Driver 2...
I have a pd360 Type 2 3.6 Volt Pivot screw driver and I don't know how to charge it? I've misplaced my paper work for the tool. Can you help me?
Usually, the battery is removed from the tool and inserted into the charger base. Hopefully, the charger has not disappeared also. Good luck!
Oct 16, 2010 | Black & Decker Garden
I don't have the supply power cord for T6510 charger
I do believe it is a 9 volt charger. Look under the battery cover and it will say how many volts. It is probably 9 volts. Just have to find a 9 volt charger with the same plug as you have. Or contact Motorola for new one. Possibly E-bay
Motorola T6510 FRS walkie talkie with charger
May 13, 2009 | Motorola T6510 XLR Talkabout Two-Way...
Computers & Internet Logo
David Payne
David Payne
