Question about Sharp Televison & Video
Hello, I Have an 80" Sharp Aquos that canstantly shuts itself off and turns back on. It' about 4 years old and started about a year ago
    Top Expert:
  • Sharp Master
  • 77,961 Answers
The problem seems to be with the power supply. There might be bad or burnt components such capacitors or rectifiers. Most of the times there are swollen caps which need replacement. I'd also suggest you to check the inverter board as well. The bad components are a result of heat or cold solders etc. If you want to repair it yourself then you should be having proper knowledge about the internal circuitry of the TV.
You should also have a multimeter and soldering equipments and the TV repair manual and schematics
Posted on Jan 03, 2017
Why is my 2011 Sharp Aquos TV crashing?
Sharp Aquos "crashing" - HDTV - Streaming Video & TVs - Tom's Guide
Aug 11, 2005 - 7 posts - ‎1 author Archived from groups: (More info?) I have a Sharp Aquos 37" LCD TV(37GD6U). Every now and then I can turn it on,
Oct 20, 2015 | Sharp Televison & Video
Sharp Aquos has distorted colors
The set should be transported upright but that rarely causes these issues-----suspect either main signal board or also possible is the power supply (for voltages changing when set is on).
Also if set was opened look for all plugs to be seated--ones with cloth tape where they connect look at first.
failing that based on age of set consider having a technician look at it or if over 3 years consider a new set with extended warranty--70% of this type of set in our shop (100 plus sets at any time in for repair) are less than 3 years old.
Oct 29, 2012 | Sharp AQUOS LC-42D43U 42" HDTV LCD TV
I have a sharp aquos model Sharp Aquos LC-20B2U 20 in. LCD Television . it works great for about 2 years, then suddenly shut down by itself. then it turns on again for a variable time, then once again...
if your TV lights the indicator when you power it on,, your problem is your back light is busted you can replace that and when the indicator not lights the problem is your power supply you can fix it by finding defective parts by using multimeter usually the trouble that i encounter to power supply is open/change value of resistor leak capacitor and shorted diode and transistor such as regulator you're always welcome
Mar 05, 2011 | Sharp Aquos LC-20B2U 20 in. LCD Television
TV shutting off by itself
The power supply is going bad and should be replaced but for the cost you will pay for the repair you can buy a new TV. Get the extended warranty, it will pay for itself.
Aug 04, 2009 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Aquos turned itself off and won't turn on again
hi....Your micro chip is faulty check the voltage comming out of the 42nd leg it shuold be 13 volts dc if you are not getting that voltage replace the microchip.and the eeprom IC....
thank u rate me!!
May 24, 2009 | Sharp Aquos LC-15E1U 15 in. LCD EDTV
My Sharp Aquos started turning off by itself about two weeks ago. It would flash off and then turn back on -- no problem after that. Then the problem grew more and more frequent until this last weekend, it...
this is due to a bad pc control board in the t.v. i had the same problem and that was the only way to fix it. i had to call sharp and they sent a tech to my house to install the new part.
May 11, 2009 | Sharp Aquos LC-13B2U 13 in. LCD Television
I lose the sound on my 1 year old SHARP aquos Lc-42D62U tv??
There is a fix for this. Call a Sharp servicer or Sharp electronics the cost of repair is around 200.00 dollars.
Apr 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-32D41U pictures problem
I have had exactly the same problem. Sounds daft but by not using the remote, and only using the power on/off switch on the TV itself, it is working idea why
Use the remore for changing programmes etc but not for on/off
Try it anyway because I know how annoying this is
Mar 29, 2009 | Sharp LC-32D41U 32 in. LCD Television
Sharp Aquos LC-32D40U-picture goes off at random times
The bad news,your set needs a new inverter board installed.With persistence to sharp,you might be able to get them to pay for the parts.
Jan 10, 2008 | Sharp Aquos LC-32D40U Television
Televison & Video Logo
24 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
