I cleaned and washed the filters now the heap fi
2 Suggested Answers
  • 1510 Answers
SOURCE: I cleaned my vacuum cleaner washed out the filters all parts were dried completely - put back together - heap filter on front keeps blowing out
The filter is likely clogged and needs replaced.
Posted on Jan 04, 2017
Electrolux washer error is EF2, too much suds, problem is I cannot get it to run to clean it our, how do I get it to restart/ It tries to start then turns off
Sounds like your drain pump, filter or waste hose is blocked, and the machine is not emptying. Or you may have a sock or something stuck in the sump hose preventing the water from running out the drum. You will have to investigate the cause of the blockage - if you machine has a filter, try removing this first! but be aware water will flood out when you remove the filter - be prepared for floods with a bowl or heaps of towels, etc.
If connected to a u trap on a sink, look there next - may be blocked with fluff or grease from the sink. Can you hear the drain pump running, but no water flows? definitely a blockage in this case.
Jan 19, 2018 | Electrolux Washing Machines
How should I clean the ribbed filter? Can I rinse it under a tap?
If it is a heap filter just replace it. If it is a foam type clean it an let it dry. Then put back in unit. Heap filters are like a paper with a wax on them an are very stiff. Just get a new one they last for years.
Jan 27, 2016 | Vacuums
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
May 15, 2014 | VAX Appliances Vacuums
How to reset fi on blackbird
Guessing
FI =Fuel Injection. Indicates a fuel system problem. locate fuel filter, clean or replace. Check for sediment in fuel tank. Faulty Injector may need to be removed , cleaned or replaced.
May 13, 2014 | 2002 Honda CBR 1100 XX Super blackbird
How do I change the belt on my bissell 6594c vacuum?
If yours looks like this one: http://www.bissell.com/ProductDetail.aspx?id=9778
lay the vacuum upside down, remove the screws that hold the plate over the brush roll, or some models just have tabs. Remove the plate and then take the brush roll out of the body. Place the new belt on the metal motor shaft and loop the brush roll pulley thru. Pull forward and place the roller into the housing, turn by hand a few rotations to make sure the belt is tracking straight. Replace the bottom plate and secure with either screws or click tabs in place. Flip vacuum over and it's ready for use. Make sure to keep your filters as clean as possible otherwise you will lose suction. You can wash any foam filters in the sink, but let them completely dry before re installing them; do not wash pleated heap filters, see owners manual for care and replacement.
Nov 03, 2013 | Vacuums
Sludge on clothes after washing
Try washing the machine without clothes , on hot wash warm rinse. Pending on how much laundry you do - is how often you should run a ghost load/cleaning cycle.
Aug 09, 2013 | Fisher and Paykel Washing Machines
Moldy smell from front-loader Asko washer.
Hi
First check to make sure that the machine is draining properly and that the pump filter is clear of any debris.
On a frontloader a common place for mold to build up is the rubber seal around the door. Clean this out as well as you can with ordinary kitchen cleaner then place a heaped cup of baking soda directly into the drum and run an empty hot/boil wash on a full cycle.
Baking soda has a cleaning and neutralising effect and will help remove any build up of mold or gunge within the machine. You may need to run two of these washes before you see a solid result.
Thereafter I recommend you run a monthly 'maintenance wash' with the baking soda to prevent the problem arising again.
Hope this helps. Thanks for using FixYa
Nov 15, 2009 | Asko W6461 Front Load Washer
After washing my machine smells like stagnant water
Hi
If the machine is a frontloader a common place for mold to build up is the rubber seal around the door. Clean this out as well as you can with ordinary kitchen cleaner then place a heaped cup of baking soda directly into the drum and run an empty hot/boil wash on a full cycle.
Hope this helps. Thanks for using FixYa.
Sep 26, 2009 | Whirlpool Washing Machines
Dirt left in creases after washing clothes. Clothes never look clean
Too many clothes in the load , if it says 5lb then that is the maximum you should fill it with otherwise the clothes do not seperate as they are being agitated
Also
Not enough detergent (Try the old powder types)
Hard Water area (Use a small amount of Washing Soda)
Water level too low , use add water button if fitted
May 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
