Our Carnation CR180 Bsnk Notr Counter feeder works, but the display is not working.
DP760 Kyocera document feeder plugged in but not registering
1087 1087 then 906 turn off and back on if there is no problem with the dp 760 it should work fine
Sep 18, 2016 | Kyocera Office Equipment & Supplies
BMW voice control not working
Thank god this is NOT one of those new autonomous cars that for awaits your voice command to move.
Trouble shoot using basic
BMW Voice Commands
There are a few software versions and hence you may want to check out
Aug 17, 2016 | BMW Cars & Trucks
Dcp-130c unable to clean 5A
looks like something is blocking paper feeder, roller or the caret. check for some unwanted parts of paper or paper clips.
Mar 20, 2014 | Brother DCP 130C All-In-One InkJet Printer
Need to know which memory card adapter is compatible with my laptop
If it doesn't fit into your laptop then you probably need some kind of adaptor, rather than trying to find the exact one you need, the best thing to do is to just buy one of these:
Then you will only ever need this (it was one of the cheapest I could find) I have had a similar one for years.
Nov 11, 2013 | Toshiba Satellite P755-S5320 Core i3-2330M...
Headlights notr working
My bright headlights stopped working and the problem was the relay under the dash had melted the plastic case and I had to replace it. I just used a generic 30 amp relay for the fix.
Aug 25, 2010 | 1983 Cadillac Eldorado
The feeder takes several sheets at a time. How do
When ever you face such type of issue, the Scanner will display U-2 error with the Red led blinking and the TWAIN display will be "The multi feed is detected.(Code DS32006)".
To resolve the issue, please follow the steps provided below:
#Check if the documents satisfy paper specification? Please refer to the Operator’s Guide for paper specification, paying
attention to the following points:
• Is there any print within 10mm x 10 mm square in the center of documents on the top?
• Is multi feed error detected by paper length when scanning documents with different length?
• Is there perforation in the center of documents?
#Check ADF and clean pick roller, Pad ASY and around DF sensor with care.
#Replace Pick roller and Pad ASY and see if the error is removed. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the permitted values, replace Pick roller or Pad ASY. If the error still occurs, confirm that the cable is correctly connected then replace the sensor.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
May 06, 2010 | Fujitsu fi-5120C
Windows media player is notr working
have you updated to media player 11 as this is designed for vista.
hope this will help
Jul 06, 2008 | Microsoft Windows Vista Ultimate Edition
Scroll button notr working
return it. its broken get an exchange
Oct 25, 2007 | Aiptek PocketCam DV Digital Camera
Epson CX3200 printer error
i just fixed the problem .. you have to reset the protection counter FIRST .. then do the reset using the triangle and colour buttons.. this it the link for the SSC utiliity to reset the counter .. my printer works fine again
Oct 18, 2007 | Epson Stylus CX3200 All-In-One InkJet...
21 people viewed this question
