Question about Roper Washing Machines
New Roper Top Load Washer bought at Lowe's. It grunts like a pig while water is filling. Makes same grunting sound during washing cycle. Is this normal?
  • 946 Answers
If it's new,it's under warranty. Don't try any m and get it repaired for free or a refund. don-ohio
Posted on Jan 03, 2017
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
I bought a new frigidaire fridge with the freezer on top. It's made a weird grunting, gurgling, groaning sound on and off from day one. Should have called Leon's where I bought it to complain but never...
hmmm, could be in defrost cycle when that happens, when the defrost element warms up and the frost/ice drips it then makes sounds about how oftern do you hear the noise?
Dec 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Aug 30, 2009 | Samsung WF203ANW Front Load Washer
Top load roper washer water will not cut off after filling machin
The water valve is the part where your water hoses connect.
Replace the water valve if the water is constantly running after the machine has been turned off.
If it only overfills during the fill cycle, check your water level switch and connecting plastic air pressure hose.
Mar 08, 2009 | Roper RAS8445KQ Top Load Washer
Roper washer fills with water continuously
Your inlet valve is defective, can be easily changed. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it. Or google 'roper washing machine spares'
Feb 23, 2009 | Roper RAS8445KQ Top Load Washer
Top Load Roper Washer does not agitate during wash/rinse cycle
You may need to replace agitator dogs located inside the agitator or the drive coupler located above the motor. It dependis on which model you have.
Jan 02, 2009 | Roper RAB2121KW Top Load Washer
I have a top load Roper washer that won't spin.Any ideas?
That sounds like a bad drum bearing, check and eventually replace the drum bearing.
Dec 28, 2008 | Roper RAS8445KQ Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Roper Washer
Most likely to be something in the water pump but could be anything in the mechanical assembly. PLease rate my help
Oct 02, 2007 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
