Question about AMP Car Audio & Video
AR 1 HI RES Bass amp repairs - AMP Car Audio & Video
Xtc 7500w amp
The amp might be on protection mode when both subs are driven...sign of an overloading problem. Does it work fine at lower volume levels? Check also the amp's supply voltage if it fluctuates out of tolerance level...might also be a loose connection in the wiring or terminals in the supply rails.
Jan 05, 2014 | Motorcycles
Rms b80 bass guitar amp has little volume in the low side jack , hi side jack is fine just not as much bass
The low in side jack has a lower vol. but should only be1/4 less than the high in jack on most amps, --try this,-- plug guitar in high in then take all the treble off and 1/2 mid. range bring up bass range and if you have equauzation bring down 26k 5k 10k about 2 notches or points. See if that give you better bass tone.
Oct 10, 2013 | Bass New Rms 40 Watt Bass Guitar Amplifier
I am looking for what an error code is: B with a 12 under it.
Code B12 is your 10,000 miles check up:
B: oil & filter change
1: tire rotation
2: engine air filter, cabin air filter change
Reset Meter:
1: turn car to ON (II)
2: press sel/res button until oil life % is displayed
3: press & hold sel/res button until oil life blinks (10 seconds)
4: release button
5: press & hold sel/res button until oil life shows 100 (5 seconds)
Hope this helps (remember to rate this answer). Good luck.
Feb 23, 2011 | Honda Odyssey Cars & Trucks
Acoustic Research AR-1 Qusetion- LFE Input and Output functions??
using the LFE input will give you cleaner less distorted bass. You must have a sub out on your receiver or pre-amp. it will give you greater control over the bass output of your system. If you only have one sub-out on your receiver simpley run a 10ft rca from the sub-out of reciever to the rca input of either speaker than use the rca out of 1st speaker to the rca input of second speaker. check to see if you have control of the level of your sub-out on your reciever. adjust the 30hz boost on rear of speakers. now you will have bass that most people only dream of having.
May 20, 2010 | Acoustic Research AR1 Speaker
Hi i cant seem to bleed my rear brakes
This is quite a common prob with older bikes:
Try to reverse bleed your system
1:Buy a large syringe and a clear tube that will fit on your bleed nipple
2:Fill up the syringe with tube attached with brake fluid(making sure that there are no air bubbles in it)
3:attach tube to calliper bleed nipple ,loosen nipple and slowly force the fluid in.
4:Tighten nipple
5:Repeat (2,3 &4)until there ar no air bubbles coming from the master cylinder res.
6:You should now be able to bleed the brake normally if needed.
Please post positive feedback for me if this has helped you
Thanks
Aug 10, 2009 | 1991 Ducati 906 Paso
Magic focus 4 error
Error 4 is listed as an overflow in the convergence section.
To fix:
1. Check the placement of the sensor
2. perform an Adjustment check of th H/V size & centering
3. Conv. amp. gain check, check these resistors:
R041, part # 0790024R, RES.CHIP 1/16W 100 OHM
R046, part # AQ00164R, RES.CHIP 1/16W 75 OHM TAPE
R050, part # 0790059R, RES.CHIP 1/16W 47K OHM
R058, part # 0790054R, RES.CHIP 1/16W 18K OHM
R062, part # 0790047R, RES.CHIP 1/16W 5.6K OHM
May 16, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I need a bass knob for my crunch amp
i need an bass knob for an planet audio rxd2400
Mar 01, 2009 | Hifonics TX1505D Car Audio Amplifier
Installation
Hi JJerky,
I suggest we go for 2 ohm to preserve the amp and not heat things up so bad.
Your Subs are Dual Voice Coil(DVC) and 2 ohms each coil. I am going to tell you the wiring to insure you get balanced response from both Subs. We will wire the Subs Voice coils in Parallel to make them 1 ohm each. Then we will wire the Amp to the subs in series to make the total load on the amp 2 ohms. When you have series to both subs each sub gets the same current.
Example of my coding :SUB1VC1+ = Subwoofer 1 Voice Coil 1 Postive terminal.
SUB1VC1+ to SUB1VC2+
SUB1VC1 - to SUB1VC2-
SUB2VC1 + to SUB2VC2 +
SUB2VC1 - to SUB2VC2 -
AMP + to SUB1VC1 +
SUB1VC1 - to SUB2VC1 +
SUB2VC1 - to AMP -
This should give you a good repsonse.
Adjust your Bass Gain down very low at first. Also cut you LPF to about 60 hz. Crank up the volume on a bass test Audio track, Adjust the Bass Gain up unitl you get distortion. The turn it back a little. This is proper setting for your Gain.
Dec 01, 2007 | Lanzar OPTI1222D Car Subwoofer
Denon 3802 Amp issue
check the output res. from the DVD, your Denon may not pass high res 720p, 1080i or 1080p and also check the component assignment in the Denons setup
Oct 08, 2007 | Denon AVR-3802 Receiver
Subs will go off the wall with bass, but not in tune with music.
hi, first disconnect the rca input, then switch on headunit and if the amp produces a constant bass thump it then means it has an internal fault. if the amp idles quietly then replace the rca cable, or try connecting the headunit lineout feed directly to the bass amp, in this way you cud find out if your fault is coming from the headunit or the equaliser. cheers
Nov 23, 2006 | MTX Thunder 8302 Car Audio Amplifier
Car Audio & Video Logo
Top AMP Car Audio & Video Experts
bigdawg7299
Billy McCain
Billy McCain
Level 1 Expert
Are you an AMP Car Audio and Video Expert? Answer questions, earn points and help others
