Question about Locks & Locksmithing
I want to set a new combination without knowing the old one.
  • 11,774 Answers
Um, that's probably not going to be possible. Take it to a locksmith.
Posted on Jan 03, 2017
We bought a home, and don't know how to open the floor safe.
You need to get a locksmith to open it. It may be possible without damage and they can set a new combination. Otherwise, they'll just break into it if you need to know what's inside.
Nov 09, 2015 | Home Security
Unlock car without keys
I have 4 dial brass combination lock, and I can not open the lock, how I can set a new combination , the existing combination is not working
Jun 30, 2013 | Locks & Locksmithing
My volumn on my ipod 4th gen is not working and when i go to settings it only shows languages no volumn setting
One of the major warnings Apple includes with all of its iPods is the permanent hearing damage that could occur if you have the volume on your iPod turned up too high.
To help combat the problem, the iPod comes with a feature that allows you to set a maximum volume level that your iPod can be played at that level is controlled by a combination that can keep others namely children from turning the volume up to dangerous levels.
The good news is, if that combination falls into the wrong hands, it can be reset.
Use your iPod's click wheel to scroll down to "Settings."
Press the center button located in the middle of the click wheel to select the settings menu.
Scroll down to "Playback" and press the center button to select it.
Scroll to "Volume Limit" and press the center button to select it.
Use the click wheel to scroll to the first number of the old combination and press the center button to select it.
Repeat this process for all four numbers of the old combination.
Use the click wheel to scroll to where you want the maximum volume to be set and press the center button.
Use the click wheel to scroll to "Lock" and press the center button.
Use the click wheel to enter the first number of the new combination when the message "Enter New Combination" appears on the screen repeat the process for the three remaining numbers.
Once the four numbers have been entered, your iPod's maximum volume will be set and your password will be changed.
hope this helps
Oct 17, 2012 | Apple iPod Audio Players & Recorders
Under settings all it will show me is language there is no volumn setting-my sound is not working correctly
hope this helps
Oct 17, 2012 | Apple iPod nano 4th Generation
I set a code in the master lock speed dial 1500id, and it will not open. I cannot reset the code and do not know how to get this open. I have read the other suggestions and nothing has worked yet. Anyone...
Try 2 options:
1. just squeeze the shackle twice and pull it out. This is in case you forgot to enter new combination.
2, Make the 2 combination together, the old and the new as one sequence. This in case you forgot to squeeze the shackle before enter new combination
Ity
Sep 06, 2011 | Office Equipment & Supplies
I have an old samsoniate vanity case bought about 16 or 17 years ago - it is open but locked with a combination which i have long since forgotten. Can you help me to reset it please
I don't know what you mean by open but locked, however, these locks can be changed to a new combination by sliding a stud inside the case (under the wheels) and holding it while setting new numbers on the wheels. I don't think this works unless you start with the wheels in the position of the old combination, though.
Nov 30, 2010 | Samsonite Tripod
I have Samsonite suitcase with the lock type B. When I used it last time, it was working. Now the code system doesn't work at all. I carefully followed the instruction to lock it but the code doesn't work,...
did you do this...
STEP 1 Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2 Locate the reset button, usually placed to the side of the combination dials.
STEP 3 Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4 Release the reset button after you set the numbers to the new combination.
STEP 5 Test the combination by turning the dials to the new code to open the lock.
if you did this then I'd contact Samsonite Customer Service at 800-765-2247.
Happy New Year
Jan 01, 2018 | Health & Beauty
Anyone know code for kenwood kdc-mp-232
Here is the manual:
http://www.masterspas.com/manuals_av/Kenwood_KDCMP232_Manual.pdf
From what I have read, you can set a new code, but you need to know the old code. You can also reset the code, but you need the old code. You can also disable the code, but you need the old code as well.
I would suggest trying different combinations of 4 digit codes, there are only 256 combinations. I am sure you will figure it out.
Jul 12, 2010 | Kenwood KDC-MP232 CD Player
Safe open but in locked position
I can't tell you how to set a new combination, without you having a tumbler key.
BUT I can tell you how to figure out the old combination.
First remove any armoured plate that covers the back and unscrew the cover plate. You will see wheels with slots cut in them. These are the tumblers. Now just like you know what the numbers are rotate the dial three times counter clockwise...then looking in through the back cover , slowly turn the dial clockwise ... look for the tumbler that is turning and stop where the slot lines up with the drop arm. Now look on the dial and write that number down. Now start on the second number by turning the dial counter clockwise until the second tumbler is lined up with drop arm. and so on
With a little patience you will figure it out.
I hope this helps you.. If you have any questions please ask.
Good Luck,
RSMITH972278
Oct 05, 2009 | Locks & Locksmithing
Locks & Locksmithing Logo
333 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
