Question about Water Heaters
How to install a vertical mount kuick hot gyser. Need installation diagram
Which position do i connect the water on the tub model american standard 6060lc.020
Uhm....i.dont understand....are you asking about how to install a tub faucet, a tub, or a drinking fountain? Never the less, hot is always on the left from the users perspective. Mount it close to the drain or on an acrylic surround for drop in installation. And as far as the drinking fountain goes. You're screwed.
Jun 18, 2014 | Ragalta Thermo Electric Hot/Cold Disp -...
How do you insulate a tankless water heater for winter
If you have tankless electric, it can simply be insulated... but tankless electric are seldom mounted outdoor.
Service bulletin says: "the only way of assuring protection is to completely remove the heater during those times the area may experience freezing temperatures.
There are tankless with built-in heater for exterior installation.
Check your manual, or add a comment with specific model number and maybe I can find the information.
Here's why they install tankless outdoors: Because tankless burn more fuel per gallon of hot water. This requires larger gas line and larger vent pipe than typical tank-type gas water heater that is usually installed indoors.
They install tankless outdoors, so there is no need for expensive vent pipe, and because there is ample incoming air to support combustion.
So if tankless does not have factory-installed internal heater, then the unit can freeze easily when the combustion draws in cold air.
Of course you can put heat-tapes on the pipes but the heat exchanger inside will quickly freeze during periods when hot water is not being used, and combustion is not taking place.
You can move the tankless installation inside and use correctly-sized vent and intake pipes directly through the wall. This will generally protect tanklesss from freezing if room is heated adequately.
Sep 26, 2012 | Rinnai Webstone The isolator EXP tankless...
Can we install a a ptg 74pvp tankless hot water heater in a closet? Would we need to install grating in the closet wall to provide more fresh air?
Rheem Tankless Water Heater Selection and Installation Videos
  • Introduction - time 04:11
  • Pre-Qualifying the installation - time 01:13
  • Selecting the Right Product - time 01:48
  • Key Differences Between Tankless & Storage Heater- time 01:27
  • Choosing the Location - time 01:20
  • Installation: Major Components - time 00:58
  • Installation: Tools Required - time 00:48
  • Installation: Mounting the Heater - time 01:15
  • Installation: Plumbing & Gas Connections - time 04:29
  • Installation: Side Wall Vent Termination - time 02:41
  • Outdoor Installation - time 01:21
  • Connecting the Remote Control - time 01:42
  • Turning on the Water Heater - time 01:00
  • Commercial vs. Residential Products - time 01:47
  • Manifolding Multiple Units - time 01:43
  • Troubleshooting & Additional Support - time 01:01
Feb 02, 2011 | Rheem Tankless Hot Water Heater...
NEED DIAGRAM ON INSTALLING UNDER SINK INSTANT HOT WATER CIRCULATING SYSTEM?
Open following link for Re-circulation information and resources, including diagram of installation and operation:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on autocirc or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2010 | Laing Thermotech Autocirc Undersink...
Would you please give me diagram install hot water cylinder
http://www.doityourself.com/stry/h2installwaterheater This is a link above is on how to install a gas and electric water heater.
This link below is off this old house of a video of how to install water heater. Along a with a description of the functions of the water heater.
I hope this will be helpful to you.
Jun 13, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Boiler bangs when hot tap turned on
Hello,You need to install a domestic/high pressure extrol/expansion tank on your cold water pipe.Should slove noise.
Apr 09, 2010 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Have a pheem 15 gallon electric hot water heater that i am trying to install and I do not know where the side mounted tpr value and pipe assembly gets tied into or does it just floats their until pressure...
the t-p valve is for pressure release, if you have to much pressure it will spout off, you need to chck the pressure comming into it should be no more than 75lbs, the tp valve has a rating of 95lbs,, it is not to do anything but just sit on the side of the water heater and should install a drip leg {section of pipe} this is for safety, when it goes off it will be hot water nd this makes it so you can get close to the water heater to shut off the supply
Jun 08, 2009 | Rheem 81VP15S/430140 Water Heater
Rinnai tankless water heater vertical vent installation
i would sugges the vertical vent comes as a complete package so i would return the complete horizontal package and ask for vertical
Nov 09, 2008 | Rinnai Water Heaters
Water Heaters Logo
44 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
