My data card cp40 prints only in one color - Office Equipment & Supplies
Changed ribbon and it comes out in black & white or faded or if in color all the same color
Goto Printer settings
advanced/
Find where Print in color
is an option. And select it.
Your printer Thinks you have a Black Ribbon in the machine.
Oct 25, 2013 | Datacard Group Cp40 Plus Card Printer...
Everything was working well, and then we ran out of ribbon. Changed the ribbon with the one that is stated on the Datacard website (535000-003) because that is what the distributor sent us instead of the...
The distributor is correct.
They are the same Ribbon.
Old Part Number : 552854-604
New Part Number :535000-003
Check the
Control Panel /
Printer setting/
Advanced/
Ribbon Type {Set to YMCKT}
If possible.
Selvol.
Sep 12, 2013 | Datacard Group Cp40 Plus Card Printer...
Error code 40.0
A connection with the card in EIO
slot X has been abnormally broken.
1. Press to resume printing.
NOTE
A loss of data will occur.
2. Check that all cables are
connected to the EIO ports
and that the EIO board is
seated properly.
3. If possible, print to another
network printer to verify the
network is working properly
Jul 24, 2012 | HP Color LaserJet 5550 Printer
Datacard CP40 Plus printer with an error. Put a new ribbon in it and it does give us a error message: Error: PR-01739 Ribbon Error Please Help!
Sounds like you are using an incompatible ribbon. Please post the configuration for the printer which is on the left side under the cover (white sticker) and your ribbon part number. If you are sure both are correct you may have a defective print ribbon or your printer will need service.
Contact TulsaBiz.net for more info
Jul 22, 2011 | Datacard SP55 Plus Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Card Pictures will not print
Change the Printer's Spool Settings.
  • Go to START - SETTINGS - PRINTERS.
  • Right Click on the PRINTER and choose PROPERTIES.
  • Under Printer Properties, select the DETAILS tab and click on the SPOOL SETTINGS button.
  • Change "SPOOL DATA FORMAT" from EMF to RAW (it may already be on this setting.)
  • Click on PRINT DIRECTLY TO PRINTER. Then click on OK.
  • Now Select the GRAPHICS or COLOR tab. If there is an option for RASTER mode, select this mode. Then lower the DPI setting and click on OK.
  • Also, make sure that the Print Mode is set to NORMAL and not Best.
  • Close the Printer Properties window by clicking on OK.
    3. Now set the printer as a default Printer. Right click on the PRINTER icon in the Printers Window and select "SET AS DEFAULT" to place a check mark by this option.
    Please try printing and let me know if that fixes it.
  • Apr 02, 2009 | Creative Home Hallmark Card Studio Deluxe...
    Canon mp630 scanner
    You can save the scanned data on a USB memory or a memory card by using the control panel.
    IMPORTANT
    - You can not use USB memory card and memory card simultaneously.
    1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
    The screen where you select where the data should be saved is displayed.
    2 .Turn the USB memory card direct print port or memory card into the slot.
    3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
    4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
    5. State the necessary settings and then press the OK button.
    6. Place the original on the glass plate as shown on the LCD screen.
    7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
    When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
    The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
    REFERENCE
    - You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
    - If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
    - You can save up to 2000 files of scanned data in both JPEG and PDF formats.
    - Folder and filename of the scanned data stored on USB memory or memory card is as follows:
    • Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
    • Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
    • Filename: Serial number, starting from "SCN_0001"
    • File dates: 01/01/2008
    Mar 28, 2009 | Canon Office Equipment & Supplies
    HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
    Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
    Hope this helps
    Thanks J
    Jan 27, 2008 | HP Color LaserJet 3500 Printer
    51 people viewed this question
    k24674
    jasbo
    jasbo
