SOURCE: scanner
Hi if you use this link it is the full users manual for the 350a everything you want to know is in it
http://www.uniden.com/pdf/BC350Aom.pdf
SOURCE: Uniden Bearcat Scanner Model# BC147XLT
The BC147XLT is too old to obtain a manual from Uniden, but here's how you program it:
Turn it on & press 'Manual', then enter the number of the channel you wish to program & press 'Manual' again. Now enter the frequency you want to put in that channel, example 155.550, and press "Enter'. Then press manual to go to the next channel or repeat the first procedure to select a different channel other than the next one. Repeat the programming procedure for each channel.
SOURCE: how do I program a BC155XL scanner?
I can't find a manual for this oldie, but generic Bearcat programming may work:
1. Press the MANUAL key to select the channel that you wish to program.
2. Enter the desired frequency, including decimal point.
3. Press the ENTER or E key.
4. Repeat the process starting with number 1.
SOURCE: how to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
4. Start over with step one to continue programming channels.
