Question about Grilling
I put the power to the smoker but it won't turn on
Why after five minutes or so of becoming hot does the grill trip my power
When you say power I am guessing you mean the ground fault switch. Struggled with that myself until recently. There are a lot of posts out there of people with this problem with a variety of smokers. Try plugging into an outlet not protected by a ground fault outlet. If the smoker works that way (mine did) I would suggest you replace the electric heating element. For $30 bucks or so this fixed my smoker. Found my part on appliancefactoryparts.com. My smoke is a Masterbuilt brand. Putting the new element in was pretty easy but a bit messy. Look for a video on YouTube for your smoker.
Good luck and happy smoking.
May 07, 2016 | Grilling
Fryer is not getting hot and power light is not coming on. What could be the problem?
Usually the problem is related in seating the heating unit correctly in the Control Mounting Bracket. If it isn't put in properly the fryer won't even power on. When you attach the heading unit onto the fryer make sure it is in both slots. Hope this helps.
Aug 08, 2011 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
We used the master built turkey fryer just once after we took turkey out it will not turn back on
That is usually a problem with placing the heating unit into the bracket correctly. If is isn't put in properly the unit won't even power on. You may need to take it off and on several times to get it right.
Jan 02, 2011 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
Plugged it and it didnt come on...i pushed the reset button too
Nov 25, 2010 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
Were do you put the wood chips
On the left side there is a tube that slides out , slide it out and you will see a place to put your chips at the far end , only place enough to not quite fill it up , push the chip loader back into the smoker all the way , give it a half turn , You have now loaded your smoker box with chips , repeat as necessary
Nov 05, 2010 | Masterbuilt 20070106 Electric Smoker
No power
Sep 26, 2010 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
Not enough screws to put smoker together
From Master Built;
If you have any questions about your unit ( or a part is missing )
give us a call FIRST before returning it to the retailer.
Ask For The Customer Service Department:
(800) - 489 - 1581 Fax (706) - 327 - 5632
Your owners manual is available for download
-->click here<--
Thanks for using Fix Ya, please take the time to rate this a Fix Ya solution.
clarkco
Feb 07, 2009 | Masterbuilt Master Barbecue 7 in 1 Smoker...
Grilling Logo
146 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
