Question about Home
WATER DRIPPING OUT OF TOP OF SANIFLOW CASING
I HAVE A TURBO FLUSH MACERATOR AND THERE SEEMS TO BE WATER COMING FROM THE TOP OF THE MAIN CASING , WHY
peterrance19
  • 399 Answers
SOURCE: Saniflow macerator is flushing most of the time.
he is correct only waste no paper or towles
Posted on Nov 14, 2009
  • 82 Answers
SOURCE: saniflow keeps on macerating after flushing
Sounds like a stuck float switch .. probably due to gunk inside the macerator. You'll need to empty all of the water out of the WC, cisterm, isolate the electricity and disconnect the saniflo (i.e. take out WC and cistern), open up the saniflo and give it a good clean
Good luck
Posted on Jan 17, 2010
  • 115 Answers
SOURCE: my saniflow dosnt allways come on when you flush
That can be a problem with the pressure chamber, the membrane might be warped or the micro switch may be defective. Open the lid and remove the motor and presure chamber. Inspect the unit for damages or any broken pieces. Check that the membrane is not warped. This can be tested manually by placing the motor on a work bench and putting pressure on the membrane to manually start the pump on and off. If parts are needed you can buy them through Saniflo directly. Their website is www.saniflo.com
Posted on Jul 30, 2010
  • 14 Answers
SOURCE: When flushed, my toilet
You need a plumber with experience with this type of toilet
Posted on Mar 21, 2011
  • 11 Answers
SOURCE: i have a saniflow for toilet and when flushed it makes a whirring noise and gradually goes to a loud crunching noise at this point i turn power supply off when turned back on its ok till next flush !p
find water pressure regulator. it will have a bolt coming out of the top with a nut at the base of it.loosen nut. while toilet is being flushed, adjust bolt till noise stops. turn bolt clockwise to adjust.
Posted on Feb 21, 2012
Saniflo ball valve replacement
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will definately help.
Dec 29, 2012 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflow macerater wont stop running
sounds like a stick float vave check this link on maintenance of your system.
Check the masserator is clear also check the outflow pipe , maybe a good clean see this link for more info
This will may help.
Dec 01, 2012 | Saniflo & Saniplus& Macerator Pump
Pump randomly runs
This problem maybe caused by a slight weep of water from the cistern the saniflow has a sensitive float system , once level is reached the unit will turn on until required level is acheaved again . So check toilet bowl to see if the is a trickle of water if so you need to take a look at the flush system in your cistern.
Nov 17, 2012 | Saniflo & Saniplus& Macerator Pump
Toilet wont flush
This will may help.
Oct 22, 2012 | Saniflo Sanicompact 48 - One Piece Toilet...
I have a saniflow for toilet and when flushed it makes a whirring noise and gradually goes to a loud crunching noise at this point i turn power supply off when turned back on its ok till next flush !p
Dec 17, 2011 | Taylor Home
.could be partialy blocked can i fix it,the system
look on saniflow website and follow the cleaning instructions in the downloadable instructions
Dec 08, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflow pump keeps comming on without flushing toilet
Water pressure makes the unit kick on and off. If it's turning on by itself then most likely somehow water is draining back into the pump. It could be leaking water from the toilet tank, to the bowl and from the bowl to the pump. Or the check valve inside the discharge elbow may not be closing all the way down and is allowing waste water to drain back into the pump creating enough water pressure that makes the pump kick on and off. Inspect the flapper on the flush valve and the check valve on the discharge elbow on top of the macerating pump.
Aug 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflow keeps on macerating after flushing, and I have to isolate it from the mains
Good luck
Dec 26, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Water leaking out of breather
I have a question, I have a saniplus no problems hooking it up filled the tank and then flushed it..On the discharge end I had a small about of water puddling up at the pressed in rubber fitting. Every clamp was tight not sure what the reason is any ideas. I thought about silcone around the rubbber seal between the lid.
Sep 08, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflow saniplus has stopped pumping water i think- the toilet and bath has filled up with waste water. i have taken the top off the saniflo and blades are working fine but they keep going because the...
We had that problem but the unit was built in and I could not get at it, the outlet pipe sounds like it is blocked, I cleared mine by connecting a pipe from the cold tap to the outlet pipe and flushing.
May 11, 2009 | Saniflo & Saniplus& Macerator Pump
Home Logo
83 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
