Question about Mercedes-Benz 2003 S500
2003 Mercedes S500 key will not turn in ignition. Battery went dead but I replaced it. Key will not disengage alarm or work on locks either.
onyeredson
  • 404 Answers
SOURCE: mercedes c220 ignition key stopped working
Hi! Sounds like the key needs to be coded again, take all relvant details i.e. chassis vin number, Registration document (Title) and key to your local Mercedes Dealership and hopefully they'll rec-code it for youor replace it.
Good Luck and a Happy New Year to You and your family.
Remember the blue FixYa button?
Paul 'W'
Posted on Dec 29, 2008
lastech
  • 408 Answers
SOURCE: 1999 Mercedes Benz CLK Old and New Key will not turn ignition
hi,seem your esl or electronic steering lock mechanism is defect,since you replaced with key,ty
Posted on Mar 30, 2009
gordanddar
  • 477 Answers
SOURCE: MY WILL NOT START THE CAR C240 MERCEDES BATTERY IS NOT DEAD
I am assuming that the engine won't even turn over. could be lots of different things. The simplist is to make sure the car in in PARK , won't start if not. Other things could be , Security imobilizer if you have one. Does your key have a electronic chip in it ? Try your other set of keys if you have one. Check if battery connections are clean and tight.
Posted on Jun 04, 2009
  • 4 Answers
SOURCE: Start Error Message when turn the key. No clicking, Dash normal.
seems like your key is not being recognized, possible your tumbler..the ring around your ignition switch is bad
Posted on Sep 21, 2009
  • 104 Answers
SOURCE: Merces Benz s500, Ignition key does not turn, can
Check Battery in car(make sure is not weak or dying), check battery in remote fob, possiable draw in system possiable fuse or possiable keyless entry module failure
Posted on Oct 20, 2009
My trunk on my 2000 mercedes s500 will not open. Battery is dead. Tried the manual lock. I am pushing it in and it still will not open
my truck on my s500 2000 model will not open at all, not will the key and not on the door the key doing everything it suppose to do with the windows and the sunroof, bnut them truck will not pop up could it be a fuse or is the the lock is stuck
Jan 29, 2011 | 2005 Mercedes-Benz CLS-Class
When i turn my key on my wife's 01 mercedes benz s500 there is no ignition light and it will not start.Everything else works just fine.The alarm,the locks and everything work ok.I have changed the car...
If your wife's key works fine and your key doesn't then there is a good possibility that your remote key is faulty. The alarm and locks may still work but those signals go to a different control module the when you try to start the car. If the ignition switch does not read the key then it will not allow you to start the car and sometimes not even turn the key in the ignition. Especially if there is any damage to the front part of the key where the red lens is at. Check and see if the infared signal is working on the remote key. To do this use a camera phone and go like your going to take a picture and point the key right at the lens of the camera phone. If it works you will see it on the screen. If it doesn't then you won't see anything when you push the button and hold it on the remote key. At the dealer they will probably ask for both keys and start by selling you a remote key.
Oct 10, 2010 | 2001 Mercedes-Benz S-Class
My mercedes s 430 2001wont let the remote key turned everything was fine the everything went dead
If you mean key will not turn in ignition,charge or jump start
Car has electronic ignition switch
If battery is low/flat it will not turn
Apr 27, 2010 | 2001 Mercedes-Benz S-Class
Battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Oct 23, 2009 | Viper Vehicle Parts & Accessories
Oct 20, 2009 | 2003 Mercedes-Benz C-Class
Mercedes c220 ignition key stopped working
Paul 'W'
Dec 29, 2008 | 2001 Mercedes-Benz C-Class
98 celica battery went dead replaced now it want crank
Try this: Unhook the battery. Reconnect the battery. When the horn starts to beep, cycle the ignition key in the ignition on-off 5 times. This resets the alarm; the cycling of the key. Please advise me if this works for you.
Oct 07, 2008 | 1998 Toyota Celica
Mercedes-Benz 2003 S500 Logo
29 people viewed this question
Top Mercedes-Benz GPS Experts
D. E. Hev
Steve from Oklahoma...
Level 1 Expert
Are you a Mercedes-Benz GPS Expert? Answer questions, earn points and help others
