Question about Panasonic Viera TC-P50S2 50" Plasma TV
Panasonic TC-P50S2 TV stopped providing picture/sound using HDMI cable connected to Directv tuner. Directv indicates the TV does not have required security preventing reproduction with HDMI cable.
  • 39 Answers
SOURCE: Picture, No Sound from HDTV Box
CON-YOU'VE DIAGNOSED YOUR OWN REPAIR.GET A NEW CABLE BOX.JOE TV
Posted on Dec 17, 2007
  • 39 Answers
SOURCE: we have connected our asus K52J lap top to our
Hi there
I've just looked at that TV model, and it appears that your TV does not support a separate audio connection for HDMI sockets. It also appears that your laptop model has a issue with sending audio via HDMI. Are you running Linux, or windows?
Hope this helps
TV_Doctor
Posted on Jan 03, 2011
SOURCE: Panasonic TV model - TC 2140T Picure and
replace the ABL Resister.
Posted on Feb 01, 2011
  • 569 Answers
SOURCE: I have a Panasonic Model TC-p42X1 TV hooked up to
It's possible that you have the wrong type of HDMI cable. You need one that has Audio Return if you want to feed your Home Theater system with audio from the TV. There are several types of HDMI cable,some with audio return and some without. The two basic types (not including Ethernet) are described below - you need the High Speed version, which does have Audio Return.
hdmi-standard.jpgHDMI Standard This is the most basic HDMI standard which all cables have to meet. Cable should contain all the connections required for HD transmission, and have to deliver at least a resolution of 720p, (Video mode of 1280 x 720 meaning 720 Horizontal lines). These cables do not contain an Ethernet connection, or audio return.
hdmi-high-speed.jpgHDMI High Speed HDMI High Speed cables will support higher resolutions of 1080p. This means at least 1080 Horizontal lines, and cables rated at this specification may well support high resolutions of up to 4096 x 2160 (2160 Horizontal lines), check individual cables specifications for this data. Cables in this specification will also support a data transfer speed of 10.2Gbs (not to be confused with ethernet data speeds which are different), and a clock speed of 320Mhz. These cables do not contain an Ethernet connection, but do include an Audio Return Channel.
Posted on Feb 03, 2011
  • 176 Answers
SOURCE: Just got Panasonic Home Theater
What kind of TV do you have?
I have found one of the easiest ways to connect surround system is to connect all your accessories (ie. Wii, Cable Box, VCR, etc) to the TV.
Next find the AUDIO OUT on the TV and connect this to the TV or AUX input on the home theater.
Tune the Home theater to the Input that you connected the TV to. This should play the audio through the home theater for any input you tune the TV to.
Note: make sure to turn the TV volume all the way down otherwise there will be some distortion due to the delay between the TV and the home theater.
Good Luck,
Robert
Posted on Feb 26, 2011
What are the best settings for the DMP-BDT330 Panasonic Bluray Player
Hello Myles, we recommend you connect the player with a HDMI cable and then set the player's output to 1080p.
Apr 27, 2014 | Panasonic Televison & Video
Panasonic TC-P54Z1 flashing image
Please remove all HDMI cables from the TV and test a different power outlet. If the problem persists then we recommend you use the below link to locate an authorized service center.
www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 21, 2014 | Panasonic VIERA TC-P54Z1 54 in. Plasma TV
Panasonic tc p50s2
It sounds like the HDMI receiver chip on your Main board is fried, probably from a power surge. You will need to find an exact replacement board on Ebay or Shopjimmy.
Mar 22, 2014 | Televison & Video
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Run DVD through tuner
ok a bit confused, Tuner ? like amplifier or Tv Tuner ? regardless seems like a easy fix .
First your cable box as 3 cables:1st . Power cable to outlet
2nd. From the wall ( usually a Coaxial cable coming from outside box ) into cable box.3rd. HDMI or Second coaxial cable ( One of these usually goes to the back or side of your Tv depending where inputs are located.)
Now Dvd has 2 cables 1st to Power2nd. To TV ( Hdmi or Coaxial )
On the back of your Tv will have 2-3 HDMI inputs . Assign 1HDMI jack to each media your trying to use.In this case TV HDMI 1, HDMI 2 DVD.
Assigning HDMI's will now reflect on your TV menu selection. Choosing HDMi 1 or HDMI2 from Tv menu will allow you use or view desired Media option in this case DVD or TV.
Now if there is Amplifier / Tuner involved like to connect surround sound to, connection may be a bit trickier however same principal.Plug all media into HDMI 1, HDMI 2, respectively,this time to the back of the tuner NOT to back of TV.Once you have done that You will need a third HDMI cable now from the back of the Tuner ( output Jack, usually has lighter color markings indicating Output HDMI) to your HDMI 1 jack in the back of your TV. Now you have bridge TV/ Cable , DVD into Receiver / Tuner and Selecting media will now be done not through TV Menu as before but through Tuner / Receiver menu or selection.
Good luck .
Good Luck
Sep 20, 2012 | Panasonic DVD-A120 DVD Player
Panasonic TC P50S2 tv loses sound fairly often. use at&t uverse hd receiver and after rebooting the dvr/receiver, the muting problem is gone for between 1 day and and 2weeks. at&t says the tv...
Use the component connection not the HDMI. Some of the ATT boxes have issues with the HDMI ports. Uverse is only broadcast in 1080i not p so you will not lose any video quality.
Apr 27, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
I cannot get sound when using an HDMI with my Panasonic Viera TC-L32X2 LCD. I have tried three different HDMI cables, I'm highly confident that is not the problem. My cable provider had to override...
Is this TV new or new to you? I suggest you check two parts of the Audio > Advanced Audio menu. First check if the TV speakers are set to on. Next check the HDMI audio setting. This should be set to Digital. (There is an analog option that works with DVI to HDMI cables and older HDMI cables that aren't fully HDMI compliant. For these situations, you connect an audio cable between the cable box and TV. I believe your audio cable needs to have a 3.5 MM (M) end at the TV and plugs in at the computer audio input.)
Since your cable provider turned off the HDCP (high definition copy protection), it's possible that the cable box is treating the cable as being incapable of carrying the audio. Try using the Analog audio option, described above. You may want to check if your cables are fully-compliant with the HDMI specification (and HDCP). Then get the HDCP enabled in the cable box. Similarly, check the audio output settings for the cable box. (If you can access the Settings for the cable box without a service call, you should look at the Audio and Display settings. My cable box has Display options for HDMI versus DVI cables, as well as a choice for Digital Audio for the HDMI option in the Display sub-menu.)
I hope these ideas help. If you need more information, add a comment with the settings for your Audio and Display settings. The manual is available on the TC-L32X2 support page, http://shop.panasonic.com/support-only/TC-L32X2.html . The direct link to the manual is currently ftp://ftp.panasonic.com/television/om/tc-l32x2_en_om.pdf . See page 28 for the Audio menu options. Since you tried three cables, I think the odds of all three being bad is slim.
Nov 01, 2017 | Panasonic TCL32X2 32 in. HD-Ready LCD TV
Just bought a new Panasonic TC-L42U22, connected it to a samsung time warner HD cable box via HDMI, but the cable remote is not working. There's picture and sound, but can't turn it on or off, change the...
You have to program the remote to work with your specific model tv. If it still doesnt work after that call your cable provider and ask them for another remote.
Mar 24, 2011 | Panasonic TCL42U22 42 in. TV
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
Panasonic Viera TC-P50S2 50" Plasma TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
